Gear shift plate replacement?
Hello, I was wondering if anyone could give me some advice on the plastic v gate on the shifter that tells you what gear your in. Mine is cracked and some of the pieces can just come off. Thanks in advance.
Check Ebay. I saw a few of them on there the other day.
Hi
There is two Ebay items that list - XJ 1998-2003 transmission shifter cover.
Here are the weblinks:
1998-2003 JAGUAR VANDEN PLAS TRANSMISSION SHIFTER COVER | eBay
1998-2001-02-2003 JAGUAR XJ8 TRANSMISSION SHIFTER COVER | eBay
You should call JagBits (888-524-2487), they might be able to get a used one for you. They have shift selector covers for some of the earlier models listed on their website.
SHIFT SELECTOR COVER (PRNDL). FITS XJS UP TO 1993 VIN 188105 WITHOUT SPEED CONTROL SWITCH (price is $25.93).
Hope this helps.
Jim Lombardi
Hope this helps.
Jim Lombardi
Try to get one where both lights work...I just bit the bullet and bought a new one for 2 bills..
The Gear Selector Illumination Module for the Supercharged Sedan (W5A580) is different than the one for the Normally Aspirated (ZF5HP24) and they have different part numbers from some MYs (VINs). I don't know what years are compatible but you cannot just plug any Selector Module into any XJ and hope it will work. It is a NODE on the CAN bus (listen only) so it is important to get the correct one or you can shut down the network.
At least get a Selector Module from a SC car to have a chance at it working correctly.
bob gauff
bob gauff
if yours is broken, you can take it apart with a couple screws and swap out a good face plate so you dont have to worry about compatabilty. I belive I also have one Ill sell you for $60 SHIPPED.Pm if interested
Hi
Jagman is only looking to replace the plastic transmission shift gate cover. The Ebay items and the JagBits items are just that - the plastic cover for the shift gate.
Sounds like Brutal has a good solution to your problem.
Jim Lombardi
Jim Lombardi
Check out this site:
2001 JAGUAR XJR SUPERCHARGED: HIT FRONT- MANY CLEAN PARTS AVAILABLE!!
Give them a call. They claim to have parts cars in stock. I'm pretty certain you'll find there what you need.
