Gear shift plate replacement?
Old Jul 14, 2011 | 09:01 PM
Jag-man's Avatar
Default Gear shift plate replacement?
Hello, I was wondering if anyone could give me some advice on the plastic v gate on the shifter that tells you what gear your in. Mine is cracked and some of the pieces can just come off. Thanks in advance.
Old Jul 14, 2011 | 10:01 PM
Scottish Chap's Avatar
Check Ebay. I saw a few of them on there the other day.
Old Jul 15, 2011 | 01:01 PM
Jag-man's Avatar
Thanks for the reply but what is the proper term for it so i can search. Thanks
Old Jul 15, 2011 | 01:33 PM
Boomer from Boston's Avatar
Not sure if you will find just the part you want - you may have to buy the whole shifter. Recyclers tend to sell cars in chunks, not each separate small piece.
Old Jul 15, 2011 | 09:23 PM
Jag-man's Avatar
ok thanks guess thats what im going to have to do.
Old Jul 16, 2011 | 06:31 AM
jimlombardi's Avatar
Hi
There is two Ebay items that list - XJ 1998-2003 transmission shifter cover.
Here are the weblinks:
1998-2003 JAGUAR VANDEN PLAS TRANSMISSION SHIFTER COVER | eBay
1998-2001-02-2003 JAGUAR XJ8 TRANSMISSION SHIFTER COVER | eBay
You should call JagBits (888-524-2487), they might be able to get a used one for you. They have shift selector covers for some of the earlier models listed on their website.
SHIFT SELECTOR COVER (PRNDL). FITS XJS UP TO 1993 VIN 188105 WITHOUT SPEED CONTROL SWITCH (price is $25.93).
Hope this helps.
Jim Lombardi
Old Jul 16, 2011 | 03:22 PM
pdog2000's Avatar
Try to get one where both lights work...I just bit the bullet and bought a new one for 2 bills..
Old Jul 16, 2011 | 03:24 PM
pdog2000's Avatar
Here is the part number for the illumination module ...LNC6195AC *- transmission module
Old Jul 16, 2011 | 09:31 PM
motorcarman's Avatar
The Gear Selector Illumination Module for the Supercharged Sedan (W5A580) is different than the one for the Normally Aspirated (ZF5HP24) and they have different part numbers from some MYs (VINs). I don't know what years are compatible but you cannot just plug any Selector Module into any XJ and hope it will work. It is a NODE on the CAN bus (listen only) so it is important to get the correct one or you can shut down the network.
At least get a Selector Module from a SC car to have a chance at it working correctly.
bob gauff
Old Jul 16, 2011 | 09:53 PM
Brutal's Avatar
if yours is broken, you can take it apart with a couple screws and swap out a good face plate so you dont have to worry about compatabilty. I belive I also have one Ill sell you for $60 SHIPPED.Pm if interested
Old Jul 16, 2011 | 09:56 PM
Hi
Jagman is only looking to replace the plastic transmission shift gate cover. The Ebay items and the JagBits items are just that - the plastic cover for the shift gate.
Sounds like Brutal has a good solution to your problem.
Jim Lombardi
Old Jul 17, 2011 | 05:13 PM
Jag-man's Avatar
Thanks for all the help and info guys, brutal I'll take you up on that offer.Can you send me some pics?
Old Jul 18, 2011 | 10:10 AM
Brutal's Avatar
Ill post them tonight
Old Jul 18, 2011 | 09:33 PM
Brutal's Avatar
here are some pics. let me know if you have questions
Attached Thumbnails Gear shift plate replacement?-p7180001.jpg   Gear shift plate replacement?-p7180003.jpg   Gear shift plate replacement?-p7180004.jpg
Old Jul 19, 2011 | 08:47 PM
Jag-man's Avatar
Looks good. shoot me your paypal info and i'll send the funds. Thanks
Old Apr 6, 2012 | 09:08 AM
99 White VDP's Avatar
Default Plastic transmission shift gate cover
Does anyone have a plastic transmission shift gate cover like the one Brutal offered above? Mine is cracked as well and I would like to swap it out. Thanks.
Old Apr 6, 2012 | 09:09 AM
Brutal,
Do you happen to have another cover?
Thanks,
Brian
Old Aug 27, 2012 | 09:49 AM
azeteg's Avatar
I'd love to get the same cover for my XKR with the 6sp ZF box. Been searching all over the place...
Old Feb 21, 2013 | 12:41 PM
sergey.v.klimov's Avatar
I'm looking for one as well...
Old Feb 21, 2013 | 11:49 PM
Tirefriar's Avatar
Check out this site:
2001 JAGUAR XJR SUPERCHARGED: HIT FRONT- MANY CLEAN PARTS AVAILABLE!!
Give them a call. They claim to have parts cars in stock. I'm pretty certain you'll find there what you need.
