XJ ( X351 ) 2009 - 2019
20 Inch OEM Jaguar Rims - Staggered 2018 Jaguar
Old May 2, 2025 | 04:26 PM
JaguarXJL15's Avatar
Default 20 Inch OEM Jaguar Rims - Staggered 2018 Jaguar
20 Inch OEM Jaguar Rims - Staggered Came off 2018 Jaguar XE Tire Sizes: Front: 235/35 R20 92Y Rear: 265/30 R20 94Y
What do you guys think these will look good on the XJ?
Old May 3, 2025 | 09:32 AM
clubairth1's Avatar
Community Influencer
Make sure the offset will be OK on the XJ.
Old May 3, 2025 | 11:18 AM
Leftcoast's Avatar
Can you explain what offset is?
Old May 3, 2025 | 11:49 AM
Vasara's Avatar
Offset (ET value) is how in the surface of the mating to hub area are in to the wheel.
Try this: https://www.wheel-size.com/calc/
Old May 3, 2025 | 01:25 PM
The offset of a rim refers to the distance between the mounting surface of the wheel (where it bolts onto the hub) and the centerline of the wheel.The wrong offset can cause clearance issues, affect handling, or lead to premature wear on suspension components.
Old May 5, 2025 | 02:31 PM
  • Bolt Pattern
    • Jaguar XE (2018): 5x108
    • Jaguar XJ (2015): 5x108
      Match!
  • Center Bore
    • XE: ~63.4 mm
    • XJ: ~63.4 mm
      Match!
  • Offset (ET)
    • XE: ~45–50 mm
    • XJ: ~40–45 mm
      ⚠️ Slight difference—XE wheels may sit slightly farther in the wheel well.
Old May 5, 2025 | 02:33 PM
  • Offset (ET)
    • XE: ~45–50 mm
    • XJ: ~40–45 mm
  • is this much offset ok or is it too much???
Old May 5, 2025 | 10:48 PM
Thermo's Avatar
Veteran: Navy
JaguarXJL15, based on the fact that the XJ uses a wider wheel than 265's in the rear, having the rear wheels sit in 5 mm (approx 1/4") is going to be minimal in effect. So, yes, the wheels will fit on the XJ and be usable. The one "downside" I would put on this is that having the offset be the 5mm different, this may put more stress on the bearing from the tire wanting to pop out the top of the wheel well to the side. But, this would be a minimal effect and to quantify it, I would say that you would shorten a wheel bearing life say 50K miles out of a 200K mile life. Probably not even that. The same is true for the front end.
Old May 6, 2025 | 04:16 AM
Pacer's Avatar
XE rim width and tire spec is completely different! XE uses 8+9" staggered setup and XJ uses 9+10" setup. Accordingly tires are 245/40 + 275/35 in XJ.
Those wheels look mickey mouse in XJ and tire load spec totally insufficient (92/94Y vs 99/102Y).
Old May 6, 2025 | 09:29 AM
clubairth1's Avatar
Good Point Pacer. That's another difference to take into account.
Zereldo
F-Pace (X761) / C-X17
Jan 26, 2020 07:16 PM
avinaash
XE ( X760 )
Dec 29, 2017 12:07 PM
hwa23
Aug 16, 2017 11:05 AM
Spikepaga
Apr 20, 2015 08:06 AM
OldSpiceGK
Feb 5, 2015 12:14 PM
