XJ ( X351 ) 2009 - 2019
2011 XJL alternator
Old Jan 14, 2022 | 06:09 PM
Pedro soto's Avatar
Default 2011 XJL alternator
Hello all,
I need help as to the removing and installation of a 2011 xjl alternator.
Pedro
Old Jan 15, 2022 | 03:47 AM
Access and removal procedure depends on the engine in your XJL ........
Old Jan 15, 2022 | 09:00 AM
Pedro soto's Avatar
Default Alternator Replacement
Graham,
2011 xjl supercharge with a 5.0 engine. I had a mechanic test the battery and it was good, he checked the alternator while the car was running and the output was 11.2 volts. It points to alternator. Any link to the how to remove and install will be appreciated.
Pedro
Old Jan 15, 2022 | 10:45 AM
clubairth1's Avatar
Community Influencer
Just a suggestion? Try to keep your original alternator if at all possible. Get the OEM one rebuilt and maybe even upgraded if you want.
We have had a large number of people who have continuing problems with a replacement unit. Most of the time the new one does charge but the car still sets lights and error codes.
Different reasons have been posted why it happens but no general agreement about what is the actual problem.
Old Jan 15, 2022 | 11:55 AM
Pedro soto's Avatar
Default Alternator
Thank you all for the helpful replies. I am keeping the original, local alternator shop is going to rebuild it for a fraction of a new one.
Thru trial and error I will go to work on getting it out first. Will try to not remove items unecessarily.
Pedro
Old Jan 15, 2022 | 01:29 PM
Originally Posted by Pedro soto
Graham,
2011 xjl supercharge with a 5.0 engine......
Pedro,
Thanks for the additional information. I've added engine size to your forum signature.
Unfortunately, the only X351 Workshop Manual I have is for the 3.0.
Old Jan 15, 2022 | 01:41 PM
Here's the Workshop Manual procedure for my XK with the same engine. I expect the X351 will be a similar sequence - attack it from underneath the vehicle with the shrouds removed.
Old Jan 15, 2022 | 03:23 PM
Pedro soto's Avatar
Default Alternator
Thank You for the info. It was easier than some people make it out to be. My dilemma now is that the one I took out doesn't look like an original. It has no label or part number. I am going to replace it anyway. Best brand? AC Delco or Denso?
Pedro
Old Jan 15, 2022 | 07:16 PM
Pedro
Both respected brands but the OE in my XK has a Denso label on it.
Old Jan 21, 2026 | 08:35 AM
c_cozo's Avatar
Can you please share it? or where can i find it? Thank you!
Old Jan 25, 2026 | 08:58 PM
Enosgl's Avatar
My XJ Super 5.0 had a Denso OEM. It now has a Delco Gold (rebuilt) as that is what was most readily available. It operates perfectly, no warning lights or other issues.
Chris Belmont
Dec 26, 2021 12:53 PM
Golfing8tr
May 8, 2020 05:52 PM
BlueX
Jul 20, 2017 01:48 PM
johndahlheimer
Mar 31, 2015 07:45 AM
