2013 XJL with Beep Beep issues
Hello all.
I am getting really upset with my lovely car.
A while back i was in a hurry so i stopped the car opened the door and jumped out, while still moving a little, so the jag put it self in park and stopped, but at the same time the boot opened. 🤷♂️
And after that it looks like i am strugeling with this beep beep,
I found that There was an alarm on the right rear door, Reading the codes it was on off on off on off on off, so i changed everything There, changed start battery, and back UP battery, Key fob batteries twice, but still i sometimes get the beep beep while starting the car, stopping the car, opening door (after the autolock is engaged), while backing UP, while idelig, it is completely random, but i did not have this issue before i did my jump out while moving incident.
I also drained my battery, but i think this is the light switch failing on me at the same time, New one ordered and Will be fitted, i thought that the switch could be a part of the beep beep, but that noice is klong klong when forgetting lights 😂😂😂
I would apriciate all help on this issue, or Else i must remove the beep beep horn (where is it?)
i Have been checking the forum, but it looks like it could be anything.
benole74,
You posted the same question in another thread (click here) today that received a reply. Because this duplicate thread has no replies, it should be deleted.
Stuart
Stuart
