XJ ( X351 ) 2009 - 2019
2014 Jag
Old Dec 30, 2020 | 12:54 PM
KingRT's Avatar
Default 2014 Jag
Can my local mechanic change the oil from draining it from the bottom?
Or does he need to suck it out from the top?
He claims bottom is better as it gets all the oil.
He does not work on Jags?
Thanks!
Old Dec 30, 2020 | 01:32 PM
Rummy636's Avatar
Yes they can drain from the bottom. There is a drain plug.
Old Dec 30, 2020 | 02:35 PM
Thermo's Avatar
Veteran: Navy
KingRT, can you drain from the bottom. YES. I did it twice. The issue comes that you are looking at an additional hourish of time because you have to remove the whole under plate to access the drain plug. Not a difficult job, but you are going to be paying a bit extra unless the mechanic is willing to do things on this own time.
As for amount of oil left in the engine from sucking it out I think is very minimal compared to how much oil you are putting into the car. While I haven't measured it, looking at how often I have to empty my can from oil changes, I am getting pretty much getting everything out that I am putting in.
Old Dec 30, 2020 | 06:33 PM
KingRT's Avatar
He charged $80 for Synthetic oil change and wipers.
Seemed cheap.
He has worked on my cars for decades.
Not my Jag.
Thanks for the input.
Dealer wants $200 for my Range Rover oil change. It’s still under warranty, so I will pay up and look for Warranty problems while it’s there.
Old Dec 30, 2020 | 06:50 PM
NBCat's Avatar
As Thermo points out above, unless you're having the gearbox serviced at the same time requiring removal of the undertray, the engine oil can be changed by using a suction pump.
Make sure the shop uses the correct oil filter housing tool to remove the cover as it can distort or crack.
Old Dec 31, 2020 | 01:40 PM
clubairth1's Avatar
Community Influencer
Also make SURE he puts ALL the bolts and screws back in!! There are quite a few and I have also drained the oil from the bottom but it's not necessary.
I find even the dealers leave stuff off because no one can see it. Every car I have put on a lift has missing fasteners. Might just be better to service it from the top like Jaguar recommends?
Old Dec 31, 2020 | 04:26 PM
XJsss's Avatar
KingRT on your response indicating you had an oil change and wipers for $80. The oil speced for our engines is not just a synthetic, it is a special formula and, IMHO, should not be substituted.
WHY?:Why you should only use Castrol Edge WSS-m2c925A
Posted by Member “Queen and Country” from the UK on the F-Type Forum 02-22-2019
“Jaguar has a Patent on the cam mechanism that not a lot of folks know about. It even licenses this technology to Ford.
https://patents.google.com/patent/US7841310B2/en
Basically if you open an engine from a regular car or even previous Jaguar's, you will find that oil naturally cooks on to many surfaces.
But it does not matter. These engines are fairly low tech when it comes to oil.
Your Jaguar engine get amazing performance (low end torque) by doing things with oil that no other manufacturer does.
It’s like a Swiss watch of delicate parts. The patent above is for a small pin that slides in and out. Oil moves this pin. No other engine in the world other than JLR and Ford have it.
What do you think will happen if you use oil that cooks quickly (becomes coke). Where after you turn the engine off you have heat soak.
Your engine is not built the same as other engines.
It needs just 3 things from the oil.
1. Good cleaning abilities
2. Ability to clean after long term use.
3. Not leave too much deposit.
Now you can become an engineer and figure out the perfect oil, or just use the one their engineers already blended. (WSS-m2c925A)”
Also posted by Q and C
“I can explain it in a simple way.
In other cars oil is used for lubrication, cleaning and cooling only. In our cars it’s also used for controlling the timing of the engine.”
Lastly, in the owner’s manual it reads “Castrol is "recommended" oil. WSS-m2c925A is the REQUIRED spec oil.
Old Jan 1, 2021 | 09:59 AM
KingRT's Avatar
My RR with “probably” the same engine was
$320 at the Dealer yesterday.
Oil and Wipers.
Old Jan 2, 2021 | 12:24 AM
Freddy J's Avatar
I have a 2014 XJ. My local Jag mechanic (not a dealer) charged me $106 for the filter & labor and I brought my own Castrol Edge WSS-m2c925A spec oil that I purchased on eBay. He drained it from the bottom and is quite familiar with removing and putting the tray back on. He feels it's the right way to do the job.
KingRT, unless your mechanic put in the right spec oil as pointed out by XJsss above, I'd get it out of there before you damage that engine. If he did put in the correct oil, I'd love to know where he got it. Only Jag dealers typically have it and they buy in bulk by the drum.
Old Jan 2, 2021 | 10:24 AM
clubairth1's Avatar
Just be sure that if you pay the super expensive dealer price for the magic juice that he actually uses the correct oil!!
Here was my story and I took it all the way to Engineering in the UK before I could get the dealer to change it again using the correct oil!!
Read Brutal's comments in detail. He is a factory Jaguar tech.
Wrong Oil from Dealer
Dee_
Feb 6, 2022 10:03 PM
woodturner
Nov 4, 2017 12:01 PM
Jessy
Oct 3, 2012 09:01 AM
Steve W
XJ40 ( XJ81 )
May 12, 2011 09:37 AM
MBxjr01
Mar 30, 2009 05:59 PM
