XJ ( X351 ) 2009 - 2019
2015 Jaguar XJL AWD Clunk/Slam into Reverse (Differential Movement Under Load)
Old Oct 17, 2025 | 03:40 PM
JaguarXJL15's Avatar
Default 2015 Jaguar XJL AWD Clunk/Slam into Reverse (Differential Movement Under Load)
Hi
I’m getting a clunk/slam when shifting Park ↔ Reverse on my 2015 Jaguar XJL AWD. A couple of observations from testing:
  • If I raise the rear wheels off the ground, the clunk disappears 100% and shifts are smooth.
  • With the car on the ground, I had someone shift P ↔ R while I watched underneath and I could see the rear differential move each time torque direction changed.
  • While driving, I can feel the gears changing (especially when the engine is cold) shifts don’t feel normal and there’s a harsh engagement similar to the slam I feel when selecting Reverse. otherwise feels normal; no obvious slipping or hydraulic issues, so the torque converter/transmission seem OK.
From what I can tell, this points to worn rear differential bushings (especially the front/nose bushing) allowing the diff to rotate under load. I Checked two Bushings they seem ok I could not see any cracks
Old Oct 20, 2025 | 12:29 PM
Dealership wants $37.00 each for the differential mount (#5) haha! I wonder why so cheap?
Old Oct 21, 2025 | 06:05 PM
ca3724's Avatar
The first thing to check is all of the u-joints. They are the most frequent failure point. An experienced mechanic can check all of the drive line and axle joints in about 15 min.
Old Oct 23, 2025 | 11:07 AM
I've uploaded videos of torque converter and transmission when shifting Park ↔ Reversenotice how the transmission barely moves and there is a lot of movement in the torque converter
JaguarXJL15
Jun 18, 2025 05:19 AM
Titanos
Oct 25, 2023 02:54 PM
derrickonline
Sep 21, 2015 05:34 AM
shift
Apr 1, 2015 12:51 PM
Billdalo
Feb 19, 2012 03:44 AM
