2015 x351 won’t start
As always do some homework first? We know it's a 2015 but what about the rest of it? Engine, miles, where your at?
What is the battery voltage?
What codes does the car have?
Problems and/or history before this started?
Otherwise is all just a shot in the dark!
Jman84, based on the number of codes you are getting and the variety that they are, I would say to start with replacing the battery. But, before you just blankly replace a battery, I would get it load tested. If the battery is below 75% capacity, it needs to be replaced. Then obviously replace the aux battery, but really, that has nothing to do with the issues you are seeing.
Next set of questions is you are saying that the car will not start, what do you mean by that? Is the motor turning over and not catching? Does the motor just make a click when the START button is depressed? Nothing happens? Each of these leads us in different directions.
Another question that I have based on the error codes is whether you have furry creature droppings under the hood. It is very possible that you got a little critter under the hood that made a buffet of your wiring (the insulation is made with a plant based material that critters love to eat). That would lead to a lot of errors with the same few sensors. I would be looking by the firewall to see if you have a nest somewhere and if so, I bet if you pull that nest out, you are going to find a mess of the wiring that is going to turn your stomach.
Yea don't jump the gun just yet. Follow what Thermo suggests.
Again we need more information about the car and what it's doing. Videos don't help.
Can you provided the information requested above?
What is the resting voltage of the car after it has sat all night?
What is the history of the problems? What has been done or replaced?
If you can fill in the blanks Thermo and I have been asking for we might be able to help.
