XJ ( X351 ) 2009 - 2019
2016 XJ - Infotainment system issues
Old Aug 5, 2016 | 08:36 AM
pvcomp's Avatar
Default 2016 XJ - Infotainment system issues
Hi - I have a 2016 XJR-sport, but appear to be having a number of issues with the Infotainment system. About 50% of the time when I start up there's some form of issue - bluetooth won't connect (or disconnect when not working), screen goes black, music does not work, maps refuse to fire up.
Seems to be more often when I jump in the car, start the engine and immediately put in reverse. Appears that doing anything before Infotainment systems is fully booted causes problems.
Anyone else seen similar issues?
Old Aug 5, 2016 | 02:55 PM
Stuart S's Avatar
I think you just resolved your issues - give it time to fully boot up.. Nevertheless, I'd discuss this with your dealer since you're still under warranty. Better still, bring it in so your dealer writes up a service ticket so it's documented in your car's file in case it doesn't get better. The infotainment/touchscreen system is expensive, and you want all repairs to be covered by the warranty.
Old Aug 26, 2016 | 05:29 PM
snknet's Avatar
Had same issue with black screen. Waiting for system to boot up prior to selecting gear seem to do the trick. Thanks.
Old Aug 28, 2016 | 08:26 AM
Aminov Mars's Avatar
Exactly the same issues.
Dealer promised to do an update of the software due to arrive soon.
Old Apr 20, 2017 | 06:02 PM
Danny Choi's Avatar
Glad to see that I'm not the only one with the exact same problems. Dealer updates twice, problems still remind :'( (2016XJL)
Old Apr 21, 2017 | 10:20 AM
meanweather's Avatar
Has anyone changed the stock rims on the XJL and had issues with it?
Old Apr 22, 2017 | 05:33 AM
Z20's Avatar
Z20
Meanweather you might want to start a separate or new thread for this question, but I have put aftermarket wheels on my XJL with zero issues.
Old Apr 22, 2017 | 05:01 PM
did you use the TPMS off the original rims or did you buy aftermarket ones? What size rims did you put on your XJL ?
Old Apr 22, 2017 | 05:02 PM
Z20,
Old Apr 22, 2017 | 05:09 PM
Z20's Avatar
Z20
I used the OEM sensors from my factory wheels. And I put 24 inch 3 piece wheels on the car.
Old Apr 28, 2017 | 09:19 AM
Chet Crouch's Avatar
Ive found that when you start the car you need to allow the system to come up before backing out of the garage. It will eventually come on if you don't but it takes a while. the backup camera seems to interrupt the boot process.
Glenn Andrews
Jan 14, 2021 02:00 PM
Jlewe42
US Midwest
May 1, 2016 03:17 PM
alynmurray
Apr 4, 2016 10:12 AM
guppy710
Apr 2, 2016 02:12 PM
Aug 31, 2006 02:45 AM
