XJ ( X351 ) 2009 - 2019
Accessing DMTL pump - 2015 XJL
Old Jun 14, 2025 | 06:34 AM
thom_87XJSC's Avatar
Default Accessing DMTL pump - 2015 XJL
The below thread mentions "rear end dropped" - I need to access the DMTL pump like the post author did -the pump is on (left/driver side) of charcoal canister.
https://www.jaguarforums.com/forum/x...-p2406-285239/
Has anyone done this job who can describe how "rear end dropped" was accomplished? I do have access to a lift.
This is the problem I have - https://www.vehicleservicepros.com/t...clogged-jaguar
I am even open to sacrilege (creating an access from the trunk - I've did something similar on a 89 Range Rover I owned when I had to replace fuel pump vs dropping the tank
Recommendations on repair manual would be great also!
I have accessed Topix before for a different job and it was detailed on how things worked and where things are but not particularly DIY reasonably handy step by step helpful and I had technical issues with the billing so I am reluctant to try it again.
Old Jun 14, 2025 | 09:16 AM
clubairth1's Avatar
Community Influencer
You can use Topix and I have an account and have used it a bit. It's expensive and hard to download what you want. I found a cheap disc from EBay was WAY better. Also be aware the Jaguar manuals are not very good and have a tons of repetition and they are HUGE! Like 8500 pages. The crappy safety warnings are probably repeated 1000 times at least and they are worthless because they don't tell you how to fix anything.
I have several copies and different versions as I have yet to find one that covers the car 100%. I can upload them somewhere so you can get them. I also have the F-Type and XF manuals because there is so much overlap between the models.
Yes I thought at one time I would need to remove and repair this but found what you did. It's a big job. Good luck cutting holes in the car.
The rear subframe needs to be dropped and take a look in the manual (When you get one). I sorta got lucky and it ended up being a bad cat (way more expensive for sure BUT a heck of lot easier to swap out!)
I don't know how deep you want to go but I use and recommend JPART and JEPC. This is the factory exploded parts diagrams. This turned into a software mess until JPART was written for us because JEPC requires Flash Player and that's all been removed from your computer due to security problems.
Search for JPART as it's a free download in that thread.
PS; Are you sure that's the problem? Just asking because of the difficulty of the repair. I do have a complete spare DTML.
Is this the part your trying to replace?
Old Jun 14, 2025 | 12:47 PM
Hi clubairth1!
Thanks you for the reply!
I wasn't super serious about the access panel but if things get desperate.. An upload would be awesome! I could look to see if have a dropbox account or similar (unless you have one?) I'll take a look at Jpart for sure!
Yes that's it - the pump is screwed into that canister. This has happened before, the pump gets ice/water in it. Had a dealership replace it before and they didn't put the foam shield that is supposed to prevent the problem hopefully I can find foam also.
Old Jun 15, 2025 | 12:10 PM
clubairth1's Avatar
OK let's see if I can help?
Here is the list of manuals I am trying to let folks get.
These are uploaded and can be downloaded using this link.
Jaguar Manuals
It is big at 1.6 GB or so. Sad thing is since this is a free site they will only stay valid for 24 hours. So start downloading!
Old Jun 16, 2025 | 10:01 AM
WOW this is awesome!!!!
Dudeman44
Aug 31, 2014 05:18 PM
J.Bo
Oct 14, 2013 07:00 AM
XJR-99
Jun 1, 2013 03:25 PM
renaultvation
Jan 7, 2013 08:34 AM
deadboy1977
May 8, 2011 05:35 AM
