XJ ( X351 ) 2009 - 2019
Battery and fob
Old Feb 20, 2024 | 04:17 PM
Carlos Saez's Avatar
Default Battery and fob
Hi guys just recently got a 2014 XJ supersport.
The battery it's on it's way out.
I have a new battery in my BMW 650 that in the shop, they are the same spec AGM 90 amp 900cca, so my plan is to swap them, the BMW will be sold.
The thing is I would need to remove the battery from the XJ take it to the shop, swap it and drive back home to fit it in the XJ.
The Real question is if you can leave the XJ disconnected for a few hours.
​​​​​​This could not be done on the facelifted XF I previously had, you loose communication with fob and everything would need to be programmed, does the XJ stuffer from the same issue.
DockingPilot
E-Pace
May 29, 2022 11:45 AM
khsjsilver
Jul 27, 2021 09:02 AM
jagjeep
Aug 29, 2019 01:52 PM
helmsteven
Jan 14, 2018 10:31 AM
retriever-007
Dec 20, 2014 11:36 PM
