XJ ( X351 ) 2009 - 2019
Brake System Fluid Flush
Old Dec 27, 2022 | 03:03 PM
Sabrinaservicewriter's Avatar
Thank you so much for sharing your knowledge and this information! I have printed out this thread and shared it with my mechanics. Thank you thank you!!
Old Jan 4, 2023 | 08:46 AM
Na5h's Avatar
As mentioned, with the system open to atmosphere and the fluid absorbing some of the moisture, all this leads to corrosion. Brake lines get corroded and the caliper pistons get corroded. While replacing the cylinder piston may not be a huge task, you just end up with a bigger job with the lines now completely open. The domino effect. A complete brake fluid change every two to three years will go a long way to preventing this hidden corrosion...
On a side note: coolant fluid also becomes more acidic over time, and with our aluminium engines, also leads to inner coolant walls and gaskets being eaten (etched) away over time and end up causing an expensive repair. Coolant flush every few years will also go a long way to keeping the fluid fresher and reduce this etching effect.
Old Apr 13, 2023 | 11:23 PM
Ramart's Avatar
Default Dealer service cost?
Anyone able to report a recent JLR dealership service charge for brake fluid flush on an F-type?
I was quoted what I think is a high-ball figure for that job when I had my year-4 complimentary CPO service done last month (plugs, filters, oil change...); but dealer (and JLRNA) wouldn't comp the year-3 brake fluid job that I missed inadvertently (because a different JLR dealer where I bought the car last year -- just two weeks before the year-3 service was due -- had reset my service interval warning with the 160-point pre-CPO sale inspection/service and told me no further service was due for a year. Consequently, I didn't study the Passport to Service schedule regarding brake fluid and got no "service due" pop-up until last month.
Old Apr 14, 2023 | 09:02 AM
12jagmark's Avatar
Originally Posted by Ramart
... on an F-type?
Have you thought of going on the F-Type forum and asking?
This is the X351 XJ forum.
Old Apr 14, 2023 | 11:25 AM
dmchao's Avatar
^ What 12jagmark said. Luckily for you my dealer estimated brake flush and bleed on my V6 F type at $350 back in 2018. I just did it myself.
Recency of quote shouldn't matter +/- 15%.
These cars (I repeat) are not special when it comes to routine maintenance unless you have Carbon Ceramics (and even then the special part is the price). Go to an indy if you want to save money, otherwise your dealer is giving you a bad price. Why pay $150-200 per hour in labor for a routine task? I have lost all faith in the dealer network in North America. JLR Peoria & JLR Dallas was good to me, and I was good to them. Every one of my other experiences has been frought with incapability.
Old Apr 14, 2023 | 04:13 PM
Freddy J's Avatar
I paid $231 including labor, shop supply adder, tax, and fluid at my mechanic. It was worth it for me.
Old Apr 14, 2023 | 10:14 PM
VinceCh's Avatar
I'm really not trying to be a wise guy, but Google "hydroscopic vs hygroscopic."
Vince
Old Apr 15, 2023 | 09:15 AM
  #28
clubairth1's Avatar
Community Influencer
Thank you Vince! I have been using the wrong word for years and you made me research it.
I will use Hygroscopic from here on out.
Man I learn something new on here every day!
Old Apr 15, 2023 | 09:21 PM
VinceCh's Avatar
Clubairth,
You’re very welcome, and I thank you for receiving my correction so graciously!
Vince
Old Apr 19, 2023 | 08:07 AM
  #30
Na5h's Avatar
Thank you, Vince! Just learnt that the word is 'hygroscopic' and not hydroscopic! Always thought it was hydro with it being affiliated with water, as in hydroplane....
Remnant1
Jun 26, 2022 08:36 PM
RGPV6S
Sep 6, 2020 09:49 AM
orangeblossom
Sep 27, 2016 02:10 AM
turnbui
Jul 6, 2012 12:28 PM
Feb 9, 2007 11:03 AM
