XJ ( X351 ) 2009 - 2019
broken sun visor spring fix
Old Oct 27, 2021 | 01:17 PM
jakemandue's Avatar
Default broken sun visor spring fix
My 2014 XJ sun visor spring broke the visor due to the visor being made out of chicken sh** plastic instead of reenforcing the spring area with metal on the visor side. Makes me worry about the drive train on my 5.0 SC if they skimped on the visor. Called the Jag dealership here in Tampa and they didn't care, 800 USD for a new one. I was able to repair it with a typical binder clip you would use to clip a large stack of papers together. I hope this helps, it was an easy fix and doest look horrible. It feels good when open and closing
one did work, but chose to use two.
new business card holder lol
Old Oct 27, 2021 | 01:40 PM
CptChaos's Avatar
Now you’re all set if you’re driving, you only eat half a bag of chips, and don’t want the rest to get stale. Multifunction for the win!
Old Oct 27, 2021 | 03:07 PM
clubairth1's Avatar
Community Influencer
I hear you on the sun visors!!
But it's about the same with any car. I just find that visors are very poorly made everywhere and the worse thing is they are hard or impossible to repair.
Old Jan 2, 2024 | 02:59 PM
mc690's Avatar
Default And WTF with USED?!?!
$800 is the price for a new replacement plus installation costs. Used go for under $200 but for some stupid reason the mechanics first take apart the engine, getting their hands all greasy and then they decide to take apart the sun visors depositing their grease all over them. WTF!?!? Have they not heard of soap?!? Hand Degreaser?!?! it’s not like we can put these in the washing machine!!!!
NOT for Jaguar but THIS is typical quality of used & I’ve looked for months and months!
Old May 21, 2024 | 06:27 PM
XKDreams's Avatar
My new to me XKR has slight visor droop on the passenger side , that’s the right side in the States. I might try some Velcro before the binder clips. But, then again, I can’t get the built in garage door opener to work with my garage door opener. Maybe I can fashion a multifunction clip that will fix the droop and mount a manual garage remote.
Old May 22, 2024 | 07:17 AM
clubairth1's Avatar
Lots of threads on the door opener. You might need a Home Link Bridge kit as I did?
Home Link Bridge Kit Home Link Bridge Kit
Fairly cheap and usually fixes it.
Old May 24, 2024 | 12:45 AM
lotusespritse's Avatar
Are you programming the garage door remote to the car, and then the car to the garage door opener?
Old May 26, 2024 | 11:33 AM
XKDreams's Avatar
No…not sure how to do that.
Anyhow, regarding the floppy visors. Has anyone ever attempted surgery on one, to see if the innards can be repaired? Anyone have a picture of the inside?
Old May 26, 2024 | 05:22 PM
ralphwg's Avatar
You will find at least two or three threads dealing with this issue if you do a search for "floppy sun visor" in the search box at the upper right corner of this page. If that phrase doesn't work use your imagination and try a few others. This a known problem on the X150s.
Old May 26, 2024 | 05:49 PM
So you don’t have to be that guy with the 12:00 flashing on your VCR
Old May 27, 2024 | 10:04 AM
clubairth1's Avatar
Yep follow that HomelInk video above. It's not hard but you do need to follow the directions.
Old May 27, 2024 | 03:00 PM
XKDreams's Avatar
I think I did it that way. I’ll try again, before martini time.
BYW…We have a stucco house, with tile roof, and metal garage door opener. So, just to get the regular hand held remotes to work…was a pita. I installed a remote antenna, and now that works great. I dint want to go back to extremely limited range with a bridge.
I’m not blaming Jag, I’m blaming Chamberlain. Our housing development was built between 2010 and 2015. All got the same Chamberlain openers, and they just dont work with home link.
Old May 29, 2024 | 11:38 AM
XKDreams's Avatar
Found this thread that provides a better & cleaner solution to the floppy visor syndrome, IMHO.
https://www.jaguarforums.com/forum/x...or-fix-188691/
adenshillito
Apr 16, 2021 10:01 AM
XK8 Rebel
Apr 5, 2021 11:18 PM
Frog
Mar 9, 2011 11:55 AM
monz87
Sep 28, 2010 12:17 PM
