XJ ( X351 ) 2009 - 2019
Cleaning scuffs off door step
Old Feb 16, 2015 | 02:54 PM
apachegogo's Avatar
Default Cleaning scuffs off door step
The door step looks lovely when cleaned, but I have some scuff marks on them (see far right of picture).
Is there a way to get these smoothed out? How much are these to replace?
Old Feb 16, 2015 | 06:24 PM
jaglover123's Avatar
The scuff plates are satin brushed. Mine is scratched up as well.
Just clean them up by re-brushing it again.
Buy one of those 3M green pads. Go with the flow of the brushing lines. You won't get those deep scuffs off. But 80% of them will be gone in 20-30 passes. To get those deep scuffs off, you can try sanding them down with a 200 grit sandpaper and finish it up with the 3M green pads.
Old Feb 16, 2015 | 06:51 PM
They don't look like brushed aluminium to me, but if they are it certainly sounds like a plan.
Sounds like you may be looking to replace them anyway as a last resort?
If so, a general sanding down, perhaps followed by fine grade 0000 wire wool then Autosol metal polish could achieve the desired effect?
Worst case scenario you have to replace them
Old Feb 16, 2015 | 08:23 PM
niceguy753's Avatar
Default Brand New XJL Sill Plates
Hi. I have a Brand new set for sell under the marketplace if you are not able to refinish to your satisfaction.
Old Feb 17, 2015 | 12:17 AM
Do not use autosol on it. It will take away the brush lines and make it polished.
I will take a picture of mine when I have the time.
Old Feb 17, 2015 | 01:29 PM
apachegogo's Avatar
Could you provide a link?
Old Feb 17, 2015 | 01:30 PM
apachegogo's Avatar
Thank you, are you sure this won't scratch them more :-s
I'll try the wire wool if the brillo stuff doesn't work.
Old Feb 22, 2015 | 05:06 AM
Not the best picture. Notice the scuffs below the letters "JAG". After 15 minutes of the green wool and 90% of the scuffs are gone.
To get the deeper scuffs off you can try sandpaper it and than finish it off with green wool.
The first picture is before. The 2nd and 3rd are the after.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
H20boy
Dec 24, 2024 03:23 PM
bdboyle
Sep 4, 2015 06:16 AM
