XJ ( X351 ) 2009 - 2019
Display climate control(HVAC) panel
Old Sep 13, 2022 | 08:25 PM
gloriashield's Avatar
Talking Display climate control(HVAC) panel
Hi guys,
My Jag is 2017 LWB and it has 4-zone system.
I bought display climate control panel from aliexpress and I received it 2 weeks ago. Easy to install and good to use. It allows you to easily set the temperature, wind speed and seat heating/cooling settings.
It has very important problem with my Jag. Rear seat control does not work. I think the problem with the firmware. Our HVAC Panel had a "big" software update at 2016. That's why if we install a 2015 panel on a 2016, some features will not be available. My firmware is ZF-2015 V106. I'm guessing it is the firmware for pre-facelift models. By any chance, does anyone use the same product? The seller is not answering my question, now
If anybody has new firmware or other informations, please share with me.
Many Thanks!
KIM
Old Nov 5, 2022 | 05:34 PM
XJunkie's Avatar
Hey I just bought 1 of these units & if your problem haven't been solved with the rear seat controls try this:
Go to the settings screen like in the photo you have posted above & then press & hold on the version for a few seconds & it should take you to a hidden menu... where you can then make changes to the system ..
See if that work out for u
Old Nov 5, 2022 | 05:35 PM
XJunkie's Avatar
Go to the settings screen like in the photo you have posted above & then press & hold on the version number for a few seconds & it should take you to a hidden menu... where you can then make changes to the system ..
Old Nov 6, 2022 | 11:04 AM
clubairth1's Avatar
Community Influencer
The bigger problem which is invisible right now is do those units provide cooling for the back of the module?
The original Merryway units like the one I have require you to install 2 PCB's from the factory head unit into the upgraded Android head unit. These 2 boards allow the factory instrument cooling fan system to operate.
Without this cooling system the aftermarket units will fail from over heating. You also are causing a lot of heat stress to the main instrument panel as it's cooled as well.
This is not talked about by the people promoting these after market screens.
Old Nov 7, 2022 | 12:27 AM
XJunkie's Avatar
I may get an aftermarket fan for android units I have seen them for sale... has your unit ever had heating problems?
Old Nov 7, 2022 | 12:43 AM
Angry
I sincerely appreciate your interest.
Watch these video files, please. There are two problems. Of course I know hidden menu and I tried It has nothing to do with turning the feature on or off. I turned on all the necessary features for my jag.
First, the auto de-fog didn't work. (I switched to Chinese for sending to Chinese sellers.)
Second, rear seat climate control does not work well. In the display, I set it to Auto, but the Auto button does not light up and it is not pressed. The temperature control function is also unnatural.
I think this is a firmware issue. They seem to have made this panel as of 2015. The FL XJ's HVAC panels have different software. This issue can reproduced on XJ produced in 16, 17, and 18MY. (They are my friends) The seller is no longer responding to this issue.
Thank you very much.
KIM
Old Nov 7, 2022 | 12:47 AM
Thumbs up
Thanks!
There is no FAN module. But it doesn't seem like it would be a problem. Thanks for your advice. I'll take a good look!
Regards,
KIM
Old Nov 7, 2022 | 07:15 AM
clubairth1's Avatar
The fan module is stock from Jaguar? It's not an add on ALL XJ's have them from the factory? The blower is located under the steering column.
Here is a very detailed description of the entire system and pictures of the components. This is a completely unknown part of the car and has never been discussed that I can find. There is a good bit on it in the service manual but that 8000+ page monstrosity is NOT easy to use!
Here is the thread where someone asked about it and I finally did enough research to come up with the answer.
Instrument Panel Cooling Fan
Old Nov 13, 2022 | 09:30 AM
XJunkie's Avatar
Oh ok I see now... yes that most likely be a firmware issue... I see that all of these units at 1 point or another have lil glitches. My ac panel works perfectly for the most part. But the glitch I discovered mine has is that the hazard light stays illuminated all the time. No biggie though..
I have contacted the seller to see if it can be fixed.
Old Dec 5, 2022 | 06:13 AM
Tstealth32's Avatar
Do these work with front heated windshield?
Old Dec 5, 2022 | 11:47 AM
XJunkie's Avatar
Yes they have ones that work with heated windshield.. you just have to tell them your car specs when ordering
Old Jan 27, 2023 | 06:14 PM
EliteZags's Avatar
was the firmware issue ever resolved? do any AliExpress sellers have units fully compatible with 2016+ XJ?
Old Jan 27, 2023 | 06:42 PM
XJ8JR's Avatar
Can anyone confirm if the seat massagers still work with this panel?
Old Jan 27, 2023 | 06:52 PM
EliteZags's Avatar
these just replace the button controls below the main dash screen right, so shouldn't affect the functionality of being able to still control all the climate functions from the main dash screen as well?
Old Jan 27, 2023 | 08:12 PM
XJ8JR's Avatar
Oh yeah, you’re right. That slipped my mind.
Old Jan 28, 2023 | 07:13 AM
The latest fw is V110. It has solved auto de-defog function, but rear control yet, 16my later.
Old Jan 28, 2023 | 06:48 PM
XJunkie's Avatar
All functions work on my unit.. rear climate, seat massagers & all..so I would say it's good
Old Jan 28, 2023 | 07:49 PM
EliteZags's Avatar
any insights on this potential concern posted in the other forum
Among the issues with the compatibility is a serious one, in that the panel doesn't engage the cooling fan integrated in the dash, risking blowing /melting the AC unit by overheating and also wiping out the main screen above it as that will overheat too.
Old Jan 29, 2023 | 07:25 AM
All functions work on my unit.. rear climate & all..so I would say it's good
when your jag born? your xj is pre-2016 i think. if it is right, no problem.
well .. it's not a structure that could be a problem. are their talking about xj?
not yet. my friend ordered panel last week, i expect he will receive latest. i will test.
Old Jan 29, 2023 | 11:18 AM
clubairth1's Avatar
Not really EliteZags. This problem came to light by accident. I was helping a guy install a big screen in one thread and he said he has had 2 or 3 of them burn up already. He also noted the screen was hot/warm to touch. He wanted to know why this was happening. It took a lot of digging but I discovered the built in cooling system for the dash screens.
The ONLY solution is to use the factory cards like the Merryway unit does then the factory cooling system for the dash instruments AND the center stack will operate. On ALL the other big screens your NOT cooling the Android screen (and please note this part!) you have also lost the cooling for the instrument panel. It's just getting hotter and hotter as well as all the wear and tear high temperatures do to electronics.
