XJ ( X351 ) 2009 - 2019
Heads bolts tightening failed
Old Jan 2, 2021 | 04:29 AM
Udiasi's Avatar
Default Heads bolts tightening failed
So i gat the cylinder head from the rebilud and needed to get them back on.
as we started to close the bolts whit very low presure.
i didnt get to the torque meter even.
The scrowing from the block snapd.
avry bolt i sterted to tite the scrueing snapd.
Any idea what next?
and how can this happen?
Jast to be clear.
The bolts are new oem
Thitning in the rgiht order.
avrything like in the manual. And i didnt even get to the first turqe tight.
2 in each head alredy snapd. 4 in total
My gess thet all 20 of the bolts screwing will snape if i will try to close them.
Old Jan 2, 2021 | 10:57 AM
clubairth1's Avatar
Community Influencer
Man I am so sorry to see all that damage!! Looks like the bolts are pulling the Aluminum threads out of the block?
I can only suggest using Heli-coils in the block to give you steel threads. I have never seen threads pulled out so perfectly?
Old Jan 2, 2021 | 11:20 AM
Udiasi's Avatar
Seems thet will be my only chance.
but the threads are so deep in the engine block...
and so littel room to work in...
Is it possible?
Old Jan 3, 2021 | 10:37 AM
clubairth1's Avatar
Well Heli-Coil is only one of several thread repair systems. I do think Keenserts are better but it's up to you.
Take a look. I would send them an E-mail with your pictures and a description of your problem.
Keenserts
Old Jan 3, 2021 | 10:47 AM
Fraser Mitchell's Avatar
Has the engine been subject to an overheating episode ?
Old Jan 3, 2021 | 11:24 AM
Udiasi's Avatar
Keenserts
tank you so mach it will be very helpful.
Old Jan 3, 2021 | 11:29 AM
Udiasi's Avatar
yes it did.
profesional says thet to the overhiting gat the threds twisted.
i will get the block out and send it to profestinal to chack the block to see if there is any other damage.
Old Jan 3, 2021 | 02:28 PM
NBCat's Avatar
If the block is distorted due to overheating, it's better to simply install a used engine.
Old Jan 3, 2021 | 06:55 PM
Normally I would agree with you on this solution but Udiasi's location means finding a used engine will be difficult.
M. Stojanovic
Feb 8, 2018 03:38 AM
jagdohrman
Jul 9, 2017 04:26 PM
RDMinor
Jul 19, 2016 12:18 PM
Shelby676
XJ40 ( XJ81 )
Jan 31, 2011 09:25 PM
