Help needed
Right I have a few questions about the xj iv seen one that's from 2010 with 95k miles I think it's a n/a 5.0 v8 petrol I'm from the uk so dont know if models varies in the us but primarily I want to know is there any issues with the engines especially when there that sort of mileage it is said to have a full jag service history but reason I'm asking is 1 theres no more for sale over 100k and 2 been in the uk they arnt very common so I dont know if it's a case of because there isent a lot around theres no info or common faults I can find or any higher milage examples to judge it against sorry for the long post and hope some of you can help me out I'm not that up on jags as iv never owned one that's why I'm been 'that guy' and asking haha
There simply aren't that many n/a 5.0 v8 petrol XJs in the UK. The vast majority of the X351s sold in the UK are 3.0 Diesels.
(I don't think that cross-advertising is disallowed - there is a more "English-centric" XJ forum at https://www.jaguarforum.com/forumdisplay.php?f=97)
Buy it you won't regret it I have one with 130000 miles on the clock and runs as sweet as a new one I do all my one work on it and apart from the usual things ie brake pads. just make sure you change the oil every 6 months regardless of mileage next one for me is the 575 when I can afford one when you go to look at it try and go before they start it so you can listen for the timing chain to see if it makes any sound on start up if it does it need changing with the guides and tensioner
Well for me ( I have a 2014 XJR) the real key is can you DIY the repairs and maintenance?
They are complicated and expensive cars and they are not cheap to repair. But mine has been extremely reliable.
This forum is the real difference between me keeping it or getting a more common car.
As always the newer and lower the miles the better the car.
I had a 100K-6 year CPO warranty and only used it once before I ran out based on time.
I would also listen about the oil change interval. I don't agree with Jaguar on the 16K or 1 a year oil changes.
Do it as posted above.
Hi Markus. The 3-litre diesel is the same engine that went into the XF-S (X250 & X-260). I had an XF-S with 194,000 miles on it when an Audi decided to write it off 2 years ago. And the engine was still running like a well-oiled sewing machine!
I can't comment on the petrol engines except what I read on UK forums and the timing chains tensioners seem to be mentioned quite often. But my advice would be to ensure a full service history and keep it serviced (+ change the oil yourself half way betweeen services).
I think if you did all that work to your BMW at home you won't have any trouble doing the same with your XJ. I would not be too concerned about the mileage since you have service history.
Hope you report back on what you decided!
The engines are good for many miles if taken care off. Pretty fast to! I have had mine to 180 mph at least 6-8 times. Smooth as glass at speed.
cheers I understand about the cost of repairs ect that's fine you expect it with cars of this nature I just dont want to be getting a car that's at the end of its life and throw good money after bad and right well I'll keep the oil changes in mind and as for repairs I can do most things my self I had a bmw car before last for a few years and that never went to the garage once did all suspension throttle body discs and pads clutch ect so I'm quite compatent when it comes to repairs so that's not an issue either my main worry was just the engine milage as I stated iv seen non over 100k but there again there isent many about so it's hard to get a scale of how long they will go for
MerlinWizard
Sep 22, 2018 08:14 PM
Last Jaguar
Apr 7, 2013 01:28 PM
