XJ ( X351 ) 2009 - 2019
Leaking coolant (I know the location)
Old Apr 22, 2019 | 10:48 AM
witcher's Avatar
Default Leaking coolant (I know the location)
Hi,
I've a 2011 XJ 3.0D, that recently started leaking coolant.
In the picture below its leaking from the plastic part circled (not the pipe)
Anyone know what it is?
Tried to make and appointment with a mechanic buts its going to be the end of next week before he takes a look.
Thanks in advance
Old Apr 28, 2019 | 09:35 PM
Nedoerr's Avatar
I don’t have the 3.0d (I have the 5L petrol), but it looks like the coolant expansion tank return hose. On mine, the connector on the hose started leaking. I would guess yours is also a leak at the connection. A new hose will have new connectors on it and should fix the problem. Again, that’s assuming a similar problem despite dissimilar engines. Apologies in advance if this does not pertain to your situation.
Old Apr 29, 2019 | 06:02 PM
witcher's Avatar
It was the thermostat housing that split. Small enough job thankfully.
trkyam
Aug 8, 2025 04:14 PM
doriel
Feb 1, 2022 01:58 AM
Ubad2
Feb 18, 2018 11:01 AM
AC0FC
Mar 16, 2017 09:36 AM
hlgeorge
May 5, 2010 08:29 PM
