XJ ( X351 ) 2009 - 2019
Low Washer Fluid Warning - Leak?
Old Feb 9, 2015 | 10:09 PM
Stuart S's Avatar
Default Low Washer Fluid Warning - Leak?
I suspect that my 2013 XJ either has a cracked washer fluid reservoir, bad hose, or loose hose connection. The low washer fluid warning light on the right side of the instrument panel lights up about a day or 2 after I have repeatedly refilled the reservoir even though I have not used the washers.
Anyone else have this happen?
I'll let the dealer fix it since my car is still under warranty. Out of curiosity, does anyone know how to troubleshoot this to determine exactly where it is leaking from? Can't see much from on top of the engine.
Stuart
Old Feb 9, 2015 | 10:39 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
Stuart
I haven't had this happen on my 2011 XJL, but it seems to me your suspected causes might explain this phenomenon. The view around the XJ engine compartment is very restricted to say the least. You fill the washer fluid in the blue capped reservoir, and after that one can see nothing. Good luck and report back your dealers findings!
Old Feb 10, 2015 | 05:13 AM
OzXFR's Avatar
I had a similar problem on my XF.
It turned out that one of the headlight washer hoses had become unclipped from the headlight.
You can just see the end of the disconnected hose if you look real hard down the back of the headlight, dunno about an XJ though.
Difficult but not impossible to reconnect without removing any parts, but you need small and nimble hands, again that's for an XF, dunno about an XJ.
Old Feb 22, 2020 | 01:10 PM
Stuart S's Avatar
I know this is a very late follow up. The reason for the loss of washer fluid was a cracked plastic reservoir. It was replaced under warranty 5 years ago and I haven't had a problem since then.
Old Mar 26, 2020 | 03:33 AM
EmmanuelTam's Avatar
Hi Stuart,
I know it was 5 years ago but will you be able to recall whereabouts the leak on the floor? I am getting the same warning light and I could find water on the floor right in front of my right front wheel.
Old Mar 26, 2020 | 12:34 PM
Stuart S's Avatar
That's the same as mine. Odds are that your windshield washer fluid plastic reservoir is cracked, just like mine.
Old Mar 27, 2020 | 01:30 AM
Thanks Stuart!
But my mechanic said the reservoir is fine, maybe he did not check thoroughly.
This plastic milk bottle is not cheap though
Old Mar 27, 2020 | 08:49 AM
thierry_1500's Avatar
If not the reservoir, then the headlamp washer is usually the culprit, esP; if your leak is in front of the wheel.
You can get your hand on the inner washer arm via the engine compartment if you don't have too thick arms/hands (position your other hand, on the outside of the washer, it's then easier to find .
You can also insert a phone and take some pictures/videos/
Usually you'll feel/see humidity and/or quite some dry deposits on the inner arm.
BR,
Thierry
raweikert
Nov 23, 2019 12:53 PM
diablomkii
Aug 1, 2017 12:41 PM
wcoy
Dec 19, 2016 10:25 PM
Stuart S
Oct 18, 2016 03:33 AM
marktmv
Jul 8, 2010 03:01 PM
