Need Advice On Removing Stuck Injector
Have seen this done in the shop, that's about the only way to make it work without removing the head. The plug hole is quite a bit larger than the injector tip, so it will work with some luck and the right tools. A borescope and a flexible pickup tool go a long way here. Also good to blow the debris out using air while both holes are open (giggity) as best as you can.
he injector mid section is plastic so once it came out it came apart.
Life And Projects By Austin YOUTUBE
Jan 18, 2023 07:38 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
