XJ ( X351 ) 2009 - 2019
Need Advice On Removing Stuck Injector
Old Yesterday | 09:26 AM
Durvelle27's Avatar
Originally Posted by RoverJoe
Have seen this done in the shop, that's about the only way to make it work without removing the head. The plug hole is quite a bit larger than the injector tip, so it will work with some luck and the right tools. A borescope and a flexible pickup tool go a long way here. Also good to blow the debris out using air while both holes are open (giggity) as best as you can.
It came out together before falling apart
Old Today | 07:58 AM
clubairth1's Avatar
Community Influencer
I am confused here? First you say the injector broke but now you say it came out? How does it break after it comes out? I don't understand?
Old Today | 08:41 AM
Durvelle27's Avatar
Reread my post "Alright I finally got it out and it snapped in two . Lord I hope the passenger side also isn't a pain in the *** as well."
he injector mid section is plastic so once it came out it came apart.
randyb
Jan 12, 2026 08:38 PM
zoomie
Dec 8, 2025 01:10 PM
Life And Projects By Austin YOUTUBE
Jan 18, 2023 07:38 AM
Sec-Jag
Jul 2, 2022 08:43 AM
XxMerlinxX
May 8, 2021 04:42 PM
