XJ ( X351 ) 2009 - 2019
Need wiring diagram to locate a broken wire to the ambient air temperature sensor
Old Feb 7, 2025 | 10:13 AM
Nexsen's Avatar
Default Need wiring diagram to locate a broken wire to the ambient air temperature sensor
I have confirmed I have a broken wire to the ambient air temperature sensor in the driver's side mirror on my wife's 2011 XJL. It is most likely broken where it flexes when the mirrors fold or where the harness goes through the door jamb. I need a wiring diagram to show where the wire goes before it attaches to any control. What I "hope" to do if I can't find the break is splice in the sensor where it is easiest to do and abandon the sensor in the mirror. I would locate the sensor as close as possible to outside air - like in the door cavity - and realize the temperature will be a little off but currently being open and registering -40 causes HVAC problems. Can anyone refer me to these diagrams or anyone in Columbia, SC who could trace the wire and do this repair?
Old Feb 7, 2025 | 10:33 AM
http://jagrepair.com/images/Electric...%20Job%201.pdf
Old Feb 7, 2025 | 12:49 PM
Nexsen's Avatar
Thank you! Page 20 and 38 show the sensor. Page 38 shows the wires from the sensor go straight to the ECU so it might be easy to wire a sensor to the ECU and abandon the broken wire and old sensor.
I GREATLY appreciate your sending me the wiring diagrams!
Old Jun 3, 2025 | 03:17 PM
Nexsen's Avatar
You were a GREAT help sending me this book of wiring diagrams and I found what I needed on page 38 but now when I try to access those pages by clicking on the page number I am getting a 404 error.
I can still page down and get what I need but I think it has changed which seems odd.
Any reason for that? Also is there a way to search the book of diagrams? For example a search for C31-D/6 or C1E116B/21. Or do you need to manually look in all the tables? Thanks again!
Old Jun 3, 2025 | 03:43 PM
NBCat's Avatar
Here is a link to the X351 Electrical Guide if you cannot get the other one to load properly:
https://www.dropbox.com/scl/fi/1r3ho...=rlt647r1&dl=0
Old Jun 4, 2025 | 07:18 AM
Nexsen's Avatar
Thanks. I noticed "slight" differences in the two. I am sure this is a stupid question but how do I determine which one is for my wife's 2011 XJL? Is the number on the cover supposed to be part of the VIN?
Old Jun 4, 2025 | 07:56 AM
The jagrepair link still works for me.
The number should refer to part of the VIN
Old Jun 4, 2025 | 01:01 PM
Freddy J's Avatar
I had the same broken wire issue and the Jag dealership spliced it while still under warrantee. I noted that the sensor always seemed to read significantly higher than actual outside temperature and had it replaced as well. The high temp reading remained an issue. I was told that the sensor in the mirror is aimed downward so that it senses the temperature of the surface of the street and as you'd expect black asphalt in the sun gets hotter than the air thus causing the erroneously high reading. I don't know if the dealership was B.S.ing me, but placing that sensor in a better place and position is a good idea if what I was told is true.
elDariusVargas
Jan 3, 2022 06:58 PM
ControlIssues
Jan 27, 2017 08:28 AM
rlentini
Oct 20, 2016 01:39 PM
razorboy
Oct 3, 2014 03:36 PM
Fyrplg
Mar 1, 2014 01:23 PM
