XJ ( X351 ) 2009 - 2019
Noise insulation and wind noise
Old Feb 22, 2024 | 12:39 AM
DanielCh's Avatar
Default Noise insulation and wind noise
Hello, 2016 XJL 3.0 owner here.
I feel that noise insulation has degraded with time, does changing door seals and rubbers help? and also i hear a lot of wind noise at 60mph and above coming from the mirrors i think, what are your thoughts on that?
Old Feb 22, 2024 | 10:24 AM
Vasara's Avatar
Add some rubber care or dooe seal silicone to the door seals and in same go check that the seal are sitting bottom of their groove. They tend to slide out in time and then it dosent sit well against door frame. (not only XJ, but all vehicles)
Old Feb 22, 2024 | 11:00 AM
NBCat's Avatar
Another source of wind noise on the X351 is from the windscreen moldings along the A posts if the windscreen has been replaced with a non OEM glass.
Old Feb 22, 2024 | 04:07 PM
lotusespritse's Avatar
You can try putting masking tape on seams to pinpoint the source of the wind noise and then fix those areas.
Old Feb 26, 2024 | 12:44 AM
DanielCh's Avatar
my windshield was never replaced, i hear the wind noise coming from the sides i guess the wing mirrors
Old Feb 26, 2024 | 05:40 PM
ABrice's Avatar
The sound may not be wind, it could be coming from the tires by way of road noise. Check the inside tread of your front tires. If your inner tread is wearing in a “cupping” pattern, it will produce significant road noise. It will sound like wind though.
I’m experiencing this now. I bought brand new Michelin tires about 4 months ago and the ride was super quiet. I went on a 4 hour trip out of town last week and noticed that the same ”wind” sound upon my return. After looking at my tires, I noticed that they are wearing in a jagged or cupping like manner. I hear a lot of road noise now. I gotta figure out what’s the cause of the problem.
It’s worth giving your tires a check to validate or rule out irregular tire wear.
Old Feb 29, 2024 | 12:59 AM
DanielCh's Avatar
wow in only 4 months your tyres started wearing out visibly, mine were installed a year and a half ago and i do not like them , tread wear 500 so the rubber is hard which causes a harsh ride. As i said i hear the wind noise at high speeds coming from the mirrors but i will check what you mentioned anyway. Thanks!
Elizabeth Blake
Sep 17, 2019 08:12 PM
AfricanJag
Feb 18, 2015 01:30 AM
shotime92
Jul 30, 2013 10:10 PM
matade
Sep 21, 2011 06:43 AM
