XJ ( X351 ) 2009 - 2019
Overheating
Old Mar 4, 2023 | 12:09 PM
Abbas_ahmd's Avatar
Default Overheating
So today again the car leaked the coolent somehow I top it up and drove the car to work and there it started leaking alot so I took the car to mechanic nearby had to stop in between and called the recover truck to tow the car but the engine overheated all kind of steams were there and when switched it off it didn't want to start stand push the start button nothing happens car just switch off by itself. I have been looking for the leaks but was not able to find one but today.
And replaced the part
But all the previous days when I was looking for a leak couldn't see it even when the car started for like an hour or so. I don't believe this was culprit in the first place I believe this can be today because of overheat also the temp needle is mostly in the middle then it will go high suddenly.
I feel like either the issue is with water pump or thermostat valve
As just a day before it was going high on the temperature but I didn't see any leak from this pipe I was water coming out from the cap of coolent reservoir.
Do you think the engine is still fine after this because it sound fine but I am not sure as it was not tuening on and only after it colled down it start again.
Old Mar 5, 2023 | 04:00 AM
Fraser Mitchell's Avatar
Did you run the engine with no coolant in it, and if so, for how long, (miles) ? Overheating is very bad for aluminium engines like yours, as it can lead to block distortion.
Old Mar 5, 2023 | 04:32 AM
Abbas_ahmd's Avatar
Maybe a mile but like switching it off for few minutes but I had to as I was stuck in middle of the road
Old Mar 5, 2023 | 04:39 AM
Abbas_ahmd's Avatar
Old Mar 5, 2023 | 09:07 AM
12jagmark's Avatar
So sorry to hear about the condition of your newly-acquired XJ. It is sad for the majority of the people who frequent the Forum, as we generally have varying degrees of affection of these beautiful vehicles.
Considering that you bought it about 2 weeks ago and began having engine problems the day after you bought (from your descriptions in your earlier posts), I would guess that it either had pre-existing conditions with the engine, OR it just happened to have a catastrophic failure the day after you bought it (not likely).
I suggest you read through existing posts in this forum that describe cooling failures and other engine failures, to familiarize yourself with the condition of your engine.
You are not the first to have your engine fail in this way, and if you hope that everyone on the forum will re-post all of the existing experiences and descriptions, you will be left with only a small bit of what has been learned and discussed.
If there is any recourse that supports purchase of an 11 year-old vehicle in the UAE or if there was any warranty from the seller, you may want to consider that quickly, especially if there is a time limitation after the purchase.
Old Mar 5, 2023 | 09:19 AM
Abbas_ahmd's Avatar
There is no warranty on it sadly the garage guy said the engine sounds fine. Rest we will know later 🥺 I drove the car for few miles performance was fine no signs of damage yet
Old Mar 6, 2023 | 12:38 PM
clubairth1's Avatar
Community Influencer
With the age of the car I would plan to replace ALL the cooling hoses and pipes. Otherwise you will have to replace them one by one and the labor charges are the real killer on this. They are wear items and we now have some very nice life time Aluminum cooling parts in the after market.
These are highly recommended.
Old Mar 6, 2023 | 03:12 PM
Abbas_ahmd's Avatar
Yes I should change all the cooling pipes. Can you share some link for after market ones I will try to find them in uae.
Old Mar 6, 2023 | 07:22 PM
ralphwg's Avatar
You can find them on Ebay.
Old Mar 7, 2023 | 04:55 AM
griff831's Avatar
Here’s an example: https://www.amazon.ae/MITZONE-compat.../dp/B0B5WGXZ8H
Old Mar 7, 2023 | 11:35 AM
Abbas_ahmd's Avatar
It's too late now car was not starting. Suspected starter first now the garage guy told but the water on pistons on the left side engine. He have open the car head now in the morning he will open the engine next day. I am so lost as what to do it will cost alot to used motor. Shall I fix this one is guy said he will a company in the morning who check if can repair the block
DrVertigo
Oct 1, 2017 10:46 AM
tracy25
Oct 10, 2013 11:19 AM
ExKay8
Apr 20, 2013 07:01 AM
jnjsardy
29
Sep 29, 2012 03:18 PM
shaz1990
Oct 15, 2011 09:22 AM
