XJ ( X351 ) 2009 - 2019
Programmable Options
Old Aug 19, 2013 | 07:47 AM
grahambell's Avatar
Default Programmable Options
HI Guys
I would appreciate some guidance, recently purchased a XJ and wanted toconfigure some of the options I previously had on my BMW 760. For example
  • Alarm Bleep when setting alarm
  • Boot Open/Close from interior Button
  • Boot Open/Close from Key Fob
  • Headlight flash on alarm activation
  • Sunroof close from key fob
Some of the above options where dealer enabled and some were programminghacks using winkfp reprogramming the modules directly.
I was very surprised today when I took the car to the dealer and they saidit is Not possible to close the sunroof via the key fob. I thought this was theglobal closing option and dealer enabled!!
Does anyone know if this can be enabled? or if there is software availableto explore programmable options on the car other than Jaguars SDD?
I became quite successful programming the BMW and would be interested to seewhat can be done on the Jag.
Any advice would be much appreciated.
Regs
Old Aug 19, 2013 | 08:05 AM
jimbov8's Avatar
Originally Posted by grahambell
[*]Alarm Bleep when setting alarm[*]Boot Open/Close from interior Button[*]Boot Open/Close from Key Fob[*]Headlight flash on alarm activation[*]Sunroof close from key fob
Can't comment on your model but from experience,
Alarm beep is dealer programmable as would headlight flash.
Everything else you should be able to programme through the remote fob.
Not much help I'm afraid but I'm sure some one will be along with more detailed info.
Old Aug 20, 2013 | 11:03 AM
wattsn's Avatar
Unfortunately sunroof close via remote fob is not possible. Windows - yes. Sunroof - no.
Boot close is not possible via fob or interior button on dash. Open only via both options.
There are few programmable options (user or dealer) on the XJ. Very much style over substance I'm afraid. I have pushed Jaguar UK on many issues in ways in which the systems could be hugely improved by very simple additional programming but they just do not seem interested. Such a shame
Old Aug 21, 2013 | 04:06 AM
ExpatJag's Avatar
I didnt know you could close the windows through the FOB. I havent found that option.
Old Aug 21, 2013 | 08:59 AM
wattsn's Avatar
It's not a programmable option, it's standard. On UK cars anyway. Press and hold lock button and windows close, but not sunroof unfortunately.
Old Aug 21, 2013 | 11:10 AM
grahambell's Avatar
BMW had a similar attitude and that is why their software was hacked and the options enabled without their support, all the options mentioned I enabled with winkfp software. Looks like the challenge to hack Jaguar has been given
Old Aug 22, 2013 | 11:03 AM
LiquidIce's Avatar
Please keep us in the loop mate if you are successful. Would love to see the possibilities on programming it.
The one thing that does frustrate me is in the inability to remote start the engine. All of the higher end BMWs, Mercs, and Audis have it, so why not the Jags? Even a US $ 30,000 Chevrolet Malibu has that option, so it just befuddles me why a $80,000 XJ cann't have it.
Old Aug 22, 2013 | 07:20 PM
grahambell's Avatar
Will keep you all posted, looking at relevant cables as we speak I don't see many resources on coding of Jags in contrast to a huge resource for BMW's although I'm sure this will grow. Can't imagine why remote start would not be available but I guess British manufacturer don't fully appreciate the climate of other countries.
Regs
Old Aug 23, 2013 | 05:14 AM
wattsn's Avatar
Which Audis have it. My Q7 and A8 don't and did not realise there was anything above those in their range. I'm guessing just not in UK as they are too concerned we may hurt ourselves. Geez!!!
Old Aug 23, 2013 | 08:11 AM
Executive's Avatar
They just don't want you "polluting the air".
Cars these days take literally about 2 minutes to warm up and you have heat.
Old Aug 23, 2013 | 10:45 AM
avus9's Avatar
Regs
I'll admit, the ONLY thing I miss as a former BMW owner is the online tech support from fellow owners. I took full advantage of their hard work to customize mine to best convenience me.
I'll be following this thread. I'd love to remove having to press the "Accept" button before using the Nav. Also, the ability to have video continue to play on screen, regardless of speed.
Old Aug 23, 2013 | 06:10 PM
grahambell's Avatar
My car was being repaired today and I asked for the ability to have the sunroof close via key fob and even the dealer couldn't believe this is not a programmable option, so if you lock your car and forget to close the sunroof your gonna have to get back in turn on the ignition and press the button to close the roof lol,,,,,,,in this day and age!!!
Both the options you mention I managed to update on my 760, no one thought it was possible to programme TV on the move but even that was cracked, putting out of action all those hardware vendors charging £100's to achieve the same.
Found a interesting post in the Jaguar Forums to disable seatbelt gong by plugging the seatbelt in and out 8 times to disable/enable the sounder, so I am sure more options will be coming to light
Old Aug 23, 2013 | 06:37 PM
grahambell's Avatar
BMW used "Webasto" preheaters manufactured in Doncaster with a remote start I think it was called Telstart, or via a mobile phone such as the iPhone, you can make a enquiry
Webasto: Retrofitting luxury class cars with a Parking Heater
sadepol01
16
Nov 22, 2024 05:05 PM
Johncy2000
Oct 2, 2015 01:05 AM
pnwrs2000
Sep 30, 2015 01:56 PM
simongulliver
Sep 27, 2015 12:58 AM
