XJ ( X351 ) 2009 - 2019
Radiator Fans NOt Stopping. Draining Battery
Old Feb 23, 2026 | 12:15 PM
Ken O's Avatar
Default Radiator Fans NOt Stopping. Draining Battery
As the title says, my 2013 XJ Portfolio, has fans that come on a minute or so after stopping the car but never stop.
Now I know they run after driving, but this is when the car is cold. They totally drianed my battery, 2 nights ago after my daughter used the car.
I disconnecetd the battery, charged it up over night, reconnected it. Then 1 minute or so afterwards, fans roar into life like a jet engine, with an engine that is at -2c, as its cold here right now in Ontario (-8c)
The external temperatiure guge also reads the totally wrong temperature as well, shows -35c, but its actually -2c in the garage.
I will drop it off at th emechanic in the moring, but any pointers? Thermostat etc?
Old Feb 24, 2026 | 02:31 PM
Ken O's Avatar
Default found the problem
Water got into the ECU enclosure.
Fortunately, a good clean & dry and everything is back to working properly. Lucky escape.
Old Feb 25, 2026 | 10:20 AM
12jagmark's Avatar
That looks terrible - good thing there wasn't any permanent damage!
Be sure to clean it with a good electric contact cleaner, then apply a good electric contact protectant to prevent it from returning worse than you found it.
CRC has some good products for that.
Old Feb 26, 2026 | 12:57 PM
clubairth1's Avatar
Community Influencer
Thanks a bunch for coming back and posting what happened! We get so many dead end threads. I think your shop did a good job finding it.
How did you clean all that corrosion out? It looks bad.
Old Feb 27, 2026 | 12:00 PM
lotusespritse's Avatar
Did you determine how the water got in the enclosure?
I would add dielectric grease to prevent future problems.
Grant Francis
Feb 2, 2024 02:24 AM
WhyToFly
Nov 8, 2022 10:49 AM
Darrenmb
Jul 1, 2021 08:28 PM
falderfer
E type ( XK-E )
Feb 21, 2020 09:13 AM
EZDriver
Oct 18, 2011 03:30 AM
