XJ ( X351 ) 2009 - 2019
Rain-sensing wipers
Old Sep 27, 2014 | 06:03 AM
RoonieQ's Avatar
Default Rain-sensing wipers
Hi everyone,
I'm finding that my rain sensing wipers don't seem to sweep frequently enough to keep up with the level of rain hitting my windshield. I usually want them to wipe more frequently, particularly if the car is not moving (like when stopped at an intersection), but also at road speed. I have played with the sensitivity setting on the stalk to no avail, and now keep it at MAX all of the time. Because of this, I often have to resort to forcing a manual sweep just to clear the screen before the car decides to itself. It's annoying, but otherwise I can't see through it clearly (to the degree that it is unsafe).
I'm curious what others experiences are with this feature? In car's from other manufacturers that I have driven that have auto-sensing wipers, I have not had this anxiety-inducing experience as the wipers sweep before I'm thinking that I wish they would.
Any comments or suggestions much appreciated. Thanks.
Old Sep 27, 2014 | 07:41 AM
XJsss's Avatar
Many of us have found that you need to have the stalk in the off position and the rain sensor adjustment in the lowest setting. Then turn on by moving the stalk up to the rain sensing position and then select the sensitivity. This way the system resets and can pickup the rain intensity.
Old Sep 27, 2014 | 02:06 PM
RoonieQ's Avatar
I'll give that a try. Thank you for the tip.Of course...clear blue sky here today and for the next week...figures.
Old Oct 6, 2014 | 08:50 AM
GilesGuthrie's Avatar
That seems to be a kludge to me. I never adjust my wipers at all. I just leave the stalk in the first position, and the speed setting at about 75%. Very occasionally I have to force a single sweep, but that's quite rare.
Mind you, the amount of rain we get here, my wipers are usually on!
Old Oct 8, 2014 | 05:54 AM
RoonieQ's Avatar
Well, after some solid rain here and following this advice, and, a trip to the dealer - no change. Unfortunately the suggested resetting procedure made no difference that I could tell (after many attempts) and the dealer claims to have reset the sensitivity (no details on how), but all remains as it was...wiping too seldom and inconsistently in conditions which require it.
I'll be returning to the dealer and will have them dig deeper as when I had my car in , I had and LR2 as a courtesy vehicle with the same feature, and its rain-sensing wipers worked like a charm
I appreciate that its a hard thing to test at a dealership if its not raining as the wiper sensors do work; just not not as they should.
Any other suggestions? Something to flash or a sensor to replace maybe?
Old Oct 9, 2014 | 05:49 AM
Sorry to hear about your experience, although the fact that you find another JLR product to be working to your satisfaction should give you some hope.
And testing the rain sensor is pretty easy, if you have one of these:
Old Oct 18, 2014 | 07:20 AM
RoonieQ's Avatar
My car went into the dealer earlier this week. Turns out that half of the sensor had detached from the windshield. Easy fix to reattach. Now the rain-sensing is working like a charm.
Thanks to all for your support!
Old Oct 18, 2014 | 04:29 PM
johndahlheimer's Avatar
From: Mooresville, NC (Race City USA), home of most NASCAR teams.
Thank you for keeping us informed about the final fix!
Old Oct 18, 2014 | 08:10 PM
amcdonal86's Avatar
Wow! What a find! Glad you got it figured out.
I probably would've just said you're crazy and you have very high standards for window cleanliness.
Old Oct 19, 2014 | 05:15 AM
Glad to hear you've got a successful resolution.
kingdom worker
Nov 14, 2020 03:47 PM
Ferdie
Nov 26, 2018 05:42 AM
sg997tt
Oct 9, 2015 10:57 PM
davidboger
Oct 1, 2015 10:13 AM
