XJ ( X351 ) 2009 - 2019
Solid Supercharger Isolator - 3.0 Petrol
Old Mar 21, 2023 | 05:51 PM
griff831's Avatar
Default Solid Supercharger Isolator - 3.0 Petrol
Hi everyone,
I have read some on here about the solid oil-filled nylon supercharger isolator for the 5.0 engine. However, it clearly says that 3.0 Petrol engines require a different part. I found this on Amazon as an alternative to the spring isolator. Has anyone done this modification on the 3.0?
Old Mar 22, 2023 | 06:18 PM
George05's Avatar
Hi , we're did you read on here that they are "different " I really can't see this being true as they more or less the same engine and the solid plastic one that you show is used on both the 3 litre and 5 litre f type cars same engine as the xj
Old Mar 22, 2023 | 07:35 PM
griff831's Avatar
Hi George,
Actually I went to buy this one getting ready for a SC snout swap this spring. But the item description from multiple sellers says that the darker green with raised circles is only for 5.0 engines.
SUPERCHARGER COUPLER ISOLATOR OIL FILLED NYLON FITS JAGUAR RANGE ROVER LAND 5.0
Condition: New
Type: Coupler
Brand: Aftermarket
Fits : Jaguar Range Rover Land 5.0
Description:
Aftermarket Oil Filled Nylon Isolator (Coupler)
Direct replacement for the spring loaded noisy isolator in your
Land Rover Jaguar 5.0 Engine supercharger
Does not fit 3.0 liter engines
These solid isolator are direct replacements for the original spring isolators
Old Mar 23, 2023 | 01:35 AM
George05's Avatar
Hi Griff, ok I get it now on the link you provided, to be really sure I would ask over on the f type section the guys and gals over there will definitely know if you can use that on the 3 litre engine as many have replaced it
Old Mar 23, 2023 | 02:10 AM
George05's Avatar
I have made a new thread on the Ftype section for you as I know a few with both the 3 and 5 litre engines have changed this out , so you should get a few replies regarding which is the best isolater to use , have a look over their in next few days , George
Old Mar 23, 2023 | 04:19 AM
DJS's Avatar
DJS
Griff, just posted this in George’s thread on the F-type forum - a recent discussion of the different isolator options.
https://www.jaguarforums.com/forum/f...er-faq-268068/
Old Mar 23, 2023 | 12:35 PM
George05's Avatar
DJS , thanks buddy
Old Mar 26, 2023 | 06:34 PM
George05's Avatar
Only place I would buy. The new supercharged snout from would be powerhouse , sure they have an eBay shop
Steamer22
May 30, 2023 12:47 AM
magpies
Jun 27, 2019 08:46 AM
iownme
Jun 25, 2011 10:06 PM
KSims1868
Jun 14, 2008 10:34 PM
