XJ ( X351 ) 2009 - 2019
Sound adjustments
Old Apr 17, 2018 | 03:02 AM
lolshto's Avatar
Default Sound adjustments
Hi.
I have a Bowers & Wilkins audio system, but it seems I can't adjust any sound settings. I haven't found them anywhere. Anyone knows where to adjust them?
Also, it seems I can't set the analog clock on the dashboard. This is very weird. I set the clock in the multimedia system, but it's not updated on the dashboard.
Old Apr 17, 2018 | 06:01 AM
Thermo's Avatar
Veteran: Navy
lolshto, you can try this, start up your car and be on the main screen of your radio. In the upper left corner will be the "VALET" button. Put your finger on that button and hold it there for about 15-20 seconds. This will put the radio into a diagnostic mode. From there, you can scroll through to the sound adjustments. Just a warning though, under this mode, you do have the ability to program the radio and if you hit multiple buttons and click yes for "install upgrade software", you can mess up the radio. But, you have to hit a few buttons that make it obvious that you are getting into dangerous territory.
Old Apr 17, 2018 | 06:47 PM
Langstraat's Avatar
Originally Posted by lolshto
Hi.
When you altered the clock in settings you must press save to actuate.
To alter the sound settings press the music button next to mode. You may alter fader, treble mid range, sub, left right .
Old Apr 18, 2018 | 03:10 AM
lolshto's Avatar
I was able to set the clock, but not the sound settings still. Nothing helps unfortunatelly.
Old Apr 18, 2018 | 05:59 AM
Langstraat's Avatar
What happens when you select the music symbol next to the mode select button?
Old Apr 19, 2018 | 02:52 AM
lolshto's Avatar
I finally managed to find it. Thanks a lot for your help.
StevenVdl
Apr 12, 2015 01:44 PM
jagtoes
Oct 11, 2014 03:51 PM
Christian 96 XJR
Oct 18, 2012 10:27 AM
tsingtao35
May 25, 2011 04:22 PM
Dec 12, 2006 10:03 PM
