Sound adjustments
Hi.
I have a Bowers & Wilkins audio system, but it seems I can't adjust any sound settings. I haven't found them anywhere. Anyone knows where to adjust them?
Also, it seems I can't set the analog clock on the dashboard. This is very weird. I set the clock in the multimedia system, but it's not updated on the dashboard.
lolshto, you can try this, start up your car and be on the main screen of your radio. In the upper left corner will be the "VALET" button. Put your finger on that button and hold it there for about 15-20 seconds. This will put the radio into a diagnostic mode. From there, you can scroll through to the sound adjustments. Just a warning though, under this mode, you do have the ability to program the radio and if you hit multiple buttons and click yes for "install upgrade software", you can mess up the radio. But, you have to hit a few buttons that make it obvious that you are getting into dangerous territory.
Hi.
To alter the sound settings press the music button next to mode. You may alter fader, treble mid range, sub, left right .
StevenVdl
Apr 12, 2015 01:44 PM
Christian 96 XJR
Oct 18, 2012 10:27 AM
