XJ ( X351 ) 2009 - 2019
Tiny coolant hose leaking
Old Aug 14, 2025 | 06:33 PM
Nostyle's Avatar
Default Tiny coolant hose leaking
I got a leak from this tiny hose going into the engine. It branches off of the main coolant pipe and connects right under the supercharger intake.
See the pic? Above the top of the belt right under the intake tube - that brass colored inlet is leaking coolant.
What part is this, how do I order it?
Any guides for DIY repairs?
Anything I should know about this?
Old Aug 15, 2025 | 12:02 AM
lotusespritse's Avatar
It's an easy fix. Buy a kit with an upgrade metal elbow and new o-ring and holder. You push the outer ring in toward the water pump and then pull out the elbow from the water pump.
https://a.co/d/aFIdqqQ
Old Aug 15, 2025 | 02:45 AM
Nostyle's Avatar
Can you direct me to a kit? EDIT: Either you didn't post the Amazon link or I didn't see it, but thanks.
Old Aug 15, 2025 | 04:59 AM
Nostyle's Avatar
SO is this compatible for a 2014 XJ?
Old Aug 15, 2025 | 09:06 AM
Did you click on the link and look at the pictures with the comparability chart? Do you want me to buy it and come install it too? 🤣🤣🤣
Old Aug 15, 2025 | 05:38 PM
Nostyle's Avatar
Didn't see the compatibility chart, thanks again.
If you want to install it, I'm in Hawaii but the swim shouldn't be that bad, waves seem calm today. Try to make it here before dinner.
Old Aug 17, 2025 | 08:17 AM
clubairth1's Avatar
Community Influencer
This is just the beginning of coolant repairs on your car. Yes you can fix them one at a time and keep going back in to repair things as they fail one by one. Or you can plan to do it all at once and have a reliable car.
Use the search function on this forum and see what comes up? Coolant leaks are the weak spot in these cars and the number one failure point. You will be well advised to plan on replacing ALL the failure prone plastic cooling parts. We are lucky as there are now metal versions for a number of parts. These are well worth installing and easy to get.
BUT the important question? Can you DIY any of this? Again we have many threads on doing this if you can DIY the repairs.
If not I hope you have enough money.
Old Aug 18, 2025 | 05:03 AM
Nostyle's Avatar
So is there a guide on how to replace the elbow pipe? Do I have to drain the coolant first or just pull it out and put the new one in? Already checked what I could of the previous posts.
Big thanks again for the link to the elbow.
Old Aug 18, 2025 | 05:34 AM
Jaaag_drivah's Avatar
There are guides for replacement of these pipes all over Youtube and the factory service manual (linked in the stickies) also details this. It's not difficult, just time consuming.
Old Aug 18, 2025 | 07:11 AM
SuperChargedXJR's Avatar
This company sells coolant upgrade kits. I'm running one on my 2015 XJR for about 10,000 miles now.
https://euro-amp.com/collections/coo...5oTXdfUTof27ER
But fixing the coolant system isn't as simple as changing a battery. Plan to commit a FULL day, if not two, to the job of over-hauling the coolant system.
Old Aug 18, 2025 | 10:10 AM
clubairth1's Avatar
You need to replace ALL the failure prone plastic NOW. You got your warning with that first tiny failure. Ignore that and you will end up with a major failure.
Your working on borrowed time.
Old Aug 20, 2025 | 06:59 AM
Nostyle's Avatar
Great link, thanks.
Nostyle's Avatar
Stickies are providing me with dead links to the manuals...
Sean W
May 16, 2025 11:31 AM
Mike1967
Jan 25, 2023 01:57 PM
chemosabe
22
Jun 14, 2022 01:21 PM
kert1224
Dec 21, 2015 12:31 PM
sempire
Nov 18, 2010 09:20 AM
