XJ ( X351 ) 2009 - 2019
Trunk open/close options
Old Oct 9, 2018 | 07:31 AM
Sandro Felisio's Avatar
Default Trunk open/close options
Hallo you all,
this could be a stupid question but I have this issue...
I can open the rear trunk in three ways:
1) With key button
2) With rear bumper button
3) With internal button
I can close it in one way only:
1) The button on the trunk door.
The problem is that when someone ask me to put something in the trunk I can open it sit in my seat, but often the person doesn't know how to close it and should be very useful to be able to close it from inside.
There is any option to close the trunk from another button that isn?t the trunk door one?
In my audi A6 I can open and close from internal button....
Thnaks for help.
Sandro
Old Oct 9, 2018 | 11:00 AM
roviw's Avatar
On mine you can only close it from the button on the underside of the lid.
Old Oct 9, 2018 | 04:57 PM
Langstraat's Avatar
Imagine the insurance claim if you were to injure someone if YOU were able to close the Trunk remotely.
You always have the option to close the trunk manually.
Old Oct 9, 2018 | 06:18 PM
Hailers's Avatar
On Mercedes you can close it using all three. No danger of hurting anybody because when the door sees resistance when closing, it stops or opens up full. There's no good reason for the Jag to not close using all three options, none at all.
I've a '17 XJL and frankly don't remember ever trying to close it other than with the button on the lid. When I'm not so lazy as I am now, I'll give it a try with the key fob.
Old Oct 10, 2018 | 05:08 AM
christ's Avatar
My UK 2011has only one method of closing the boot, the button on the inside of the boot lid, but I believe that there are market specific variations.
Old Oct 10, 2018 | 02:51 PM
JaxR.'s Avatar
I just tried on my 2018 XJ. Boot opens just fine with the fob. Won’t close with it though. Must press the button on the lid to close. It clicks, I assume that’s the lock “opening” so in theory, it should work in the reverse as well.
This would require rewiring to enable remote closing, not just a software update?
Old Oct 10, 2018 | 03:50 PM
Thermo's Avatar
Veteran: Navy
All, looking at the diagrams for the car, making this an option shouldn't be all that difficult. Granted, to access stuff may take a little bit. In short, what you are going to end up doing is running a wire from the dash to the trunk lid computer in the boot. If you look at the computer for the trunk lid and locate pin 23, you should see a black wire there. What you are going to end up doing is adding a second wire to this pin (or upstream on the wiring) and run this wire to the dash or other location where you want the close button. From there, you can attach this wire to a momentary pushbutton. You will then need to take a second wire and run it from the other pin of the pushbutton to chassis ground. This way, every time you depress the button, you will make up the switch and apply a ground to the turnk lid computer, making it think you pressed the button on the trunk lid. That is it. Unfortunately, to make the trunk close via the keyfob would require some significant reprogramming from what I am seeing.
If you are curious where this module is located, looking at the diagrams for the car, if you remove the spare tire and then lean into the trunk and look pretty much behind where the license plate would be, you should see the module there.
Old Oct 11, 2018 | 03:21 AM
christ's Avatar
This has been discussed before - https://www.jaguarforums.com/forum/x...switch-174899/
XJL2011
Sep 19, 2024 01:06 PM
tu2side
May 9, 2018 06:06 PM
tu2side
May 9, 2018 05:36 PM
rashaw
May 8, 2012 07:37 PM
