XJ ( X351 ) 2009 - 2019
Upgrade from Supercharged to Supersport
Old Mar 22, 2018 | 01:00 PM
Jaguar EU's Avatar
Default Upgrade from Supercharged to Supersport
Hi All,
I'm having a XJ-L supercharged 470Hp.
I would be really happy to get the 510hp out the engine.
How can help me as an EU citizin.
regards Bastiaan
Old Mar 22, 2018 | 02:23 PM
Thermo's Avatar
Veteran: Navy
Bastiaan, why stop at 510 HP. From what I have read, you can get the smaller pulley through a place like Mina Gallery and then if you talk with your local dealership, they can put in the Supersport programming. That will take you to about 550 hp. Then, for a bit more, you can have a local dyno shop tweak the engine a little more and if the numbers are correct that others have said, you would be in the 620 hp range.
Old Mar 22, 2018 | 02:34 PM
Jaguar EU's Avatar
Hi Chris,
Thanks for your fast respons, anyway it isn't that I want to stop at 510Hp.
I really don't know if in my regio are dealers how are willing to do the reprogramming (first step)
And then smaller upper pulley (second step)
Does anyone know a reliable jaguar in the netherlands, mid germany or belgium?
Old Mar 22, 2018 | 06:36 PM
Enosgl's Avatar
One that I have HEARD a bit about is Arden, in Germany. Their web site is:
Arden - Jaguar, Range Rover, Bentley, MINI Startseite. You can contact Velocityap in Canada. Not sure if being a European car requires a different tune than North America or not, but the estimated power of the tune even without the pulley seems more than adequate.
Old Mar 23, 2018 | 11:45 AM
JagGate's Avatar
Perhaps here?
Jaguar/Land Rover Exhausts Headers Catalysts ECU Tuning
Old Mar 25, 2018 | 02:27 AM
Jaguar EU's Avatar
EnosGl JagGate,
Thanks a lot for the info, currently i'm working that.
I had contact with Arden in Germany, actually they sent me a quote (quite) pricy without mentioning a power gain.
And a guarantee for that it will work.
For the moment i'm waiting for an answer from Applebee's engineering.
Keep you updated
regards
bas
Old Mar 25, 2018 | 02:35 AM
Jaguar EU's Avatar
To all,
In Germany is also a dealer from veocityap.
www.jaguar-codierung.de
Just a 3hrs drive from where i live
Old Mar 26, 2019 | 12:40 PM
clubairth1's Avatar
Community Influencer
VAP has a good reputation on this forum and I am running their tunes currently on my 2014 XJR with no complaints.
Just getting ready to install lower pulley and bigger inter-cooler and upgraded IC pump.
I also have their stage 2 tune for those additional mods.
You can't go wrong with VAP on Jaguars!
Old Mar 29, 2019 | 12:48 AM
avos's Avatar
Rica in the Netherlands will be able to help you
XJ8JR
Jan 15, 2018 03:06 PM
XJsss
Aug 29, 2013 01:31 PM
sjuraud
Aug 28, 2010 02:11 PM
