XJ ( X351 ) 2009 - 2019
Wheels Upgrade
Old Jan 7, 2021 | 11:31 PM
Artie's Avatar
Default Wheels Upgrade
Happy New Year!
I finally decided to upgrade the wheels on my 2016 XJL. I decided to go with these wheels and have been patiently waiting for them to come back in stock. I know a lot of people here don't like to run big wheels, but I love the way they look and I'm ok with sacrificing some ride quality.
I'm not very familiar with sizing and offsets so I wanted to see what people that are running 22" wheels recommend. My current wheels are 19" stock wheels which I believe are x9 in the front and x10 in the back. Audio City have them 22x9 and 22s10.5 for the rear. Will those fit?
I messaged Car ID, but they only have them in 22x9 and 35+ offset. Does 35+ offset indicate that the wheels will be pushing out outside the wheel well?
I haven't decided on tire size so I would appreciate any recommendations. I'll most likely either get Michelin Pilots or Pirellis.
Old Jan 8, 2021 | 12:00 PM
XJsss's Avatar
Here is OEM specs for wheels and tires:XJ (x351) 20” Tire and Wheel Tech Specs:
--------------------------------------XJs--------------------------------------- XJR
Front Wheels: Tires 245/40/20”, Wheel 9J, 49 offset --- Tires 265/35/20”, Wheel 9J, 49 offset
Rear Wheels: Tires 275/35/20”, Wheel 10J, 44 offset--- Tires 295/30/20”, Wheel10J, 46 offset
Old Jan 10, 2021 | 02:52 PM
Artie's Avatar
Thanks.
After speaking with Axe wheels, they told me they're not planning on making any more wheels for staggered setups.
What would happen if I went with 22x9 for front and back?
Old Jan 13, 2021 | 11:44 AM
Randy Mounts's Avatar
I’m running 22s on my car and I absolutely hate it just rebuilt the complete front end by 22s will be up for sale going back to 20s good luck
Old Jan 14, 2021 | 10:22 AM
Artie's Avatar
Hey Randy,
What do you hate about it? Is the ride too rough?
Since I can't find the wheels I like in 22, I might go with 20s. I'm curious what width and offsets you're planning on going with for 20s.
Old Jan 14, 2021 | 11:15 AM
Ride to roughly, not much tire, rebuilt the entire front end this year.doing upper control arms tomorrow. Far a 20” tire specs. Not sure the tire place I go to will handle that matching original sizes.
Originally Posted by Artie
Hey Randy,
Old Jan 14, 2021 | 01:40 PM
XJsss's Avatar
Randy see my post #7 for 29" tire sixes. Many of us have talked about tires on other threads, but, IMHO Michelin Pilot Sport 4s is the finest tire out there.
Old Feb 11, 2021 | 05:28 PM
Artie's Avatar
XJsss,
Thanks for the OEM specs. I think I'm going to go with these wheels in 20s, unless I have a change of heart and go with 21s
Wish me luck. Every wheel I've found so far has been out of stock.
Old Feb 18, 2021 | 11:50 AM
Artie's Avatar
Quick question.
I'm about to place the order to get the wheels below with the recommended specs (thanks @XJsss), but the only potential issue is that the rear wheel only comes in 20x10.5" instead of 20x10" , is that going to be a big deal? I've seen people with larger wheels rocking 10.5 in the rear so I wanted to verify if this will cause issue or will require me to get a different size of tires.
Also, the place installing the wheels told me these wheels would have 35 and 45 offset. Is this fine? I just want to make sure my wheels line up with my fenders and don't stick out / in.
Wheels: Gianelle Verdi
Size: 20x9 Front, 20x10 rear
Tires: Michelin Pilot Sport 4S
Front size: 245/40ZR20
Rear size: 275/35ZR20
Old Feb 19, 2021 | 06:34 PM
Stuart S's Avatar
Check the Forum Marketplace for wheels. I've seen Vossen wheels listed there, but don't know if they're still available. Just make sure they fit the X351.
philwarner
Jun 16, 2016 04:13 PM
Pumpkinate
Jun 23, 2015 05:39 PM
albert328gts
Apr 18, 2013 11:15 PM
stran0020
Dec 3, 2009 11:20 PM
randylindberg
May 31, 2007 04:03 PM
