XJ ( X351 ) 2009 - 2019
window condensation
Old Jan 12, 2020 | 02:35 PM
Redmen's Avatar
Default window condensation
Hi, My front window has condensation on it. When defrost switched on it has gone but with auto mode it slowly comes again.
I checked service manual and found the "Evaporator drain pan" at the bottom of the climate/heater assembly but how can I clean it or remove any blocking material (dust, leaf, etc...).
Thanks for any advise - if there is any...
Old Jan 12, 2020 | 05:24 PM
clubairth1's Avatar
Community Influencer
Do you have water dripping under the car when the AC is on?
That should tell you quickly if yours is plugged?
Old Jan 13, 2020 | 02:04 AM
Redmen's Avatar
Hi, Thx for the response.
As this is winter I can not check it out correctly now but there was no water underneath in the September to November time. Also in the last few month there was moisture on the windshield when the car was starting - after a minute it has gone every time.
So how can I clean the drain out?
Old Jan 14, 2020 | 11:30 AM
clubairth1's Avatar
I am not sure because these late model Jaguars bury the condensate drain and I can't find any outlet under the car. It seems to just weep from around some of the under body panels.
The old cars would have a rubber tube and you could back flush those.
Sorry not much help I know!
Old Jan 16, 2020 | 03:56 PM
Stuart S's Avatar
Try this:
  1. Close all dashboard vents.
  2. Start engine.
  3. Set Climate Control manually to AC ON, temperature to coldest setting, and recirculate inside air.
  4. With the car parked and the engine running, use the manual fan speed controller to vary the fan speed between the fastest and slowest speeds. Repeat this for at least 5 minutes.
  5. Stop engine, exit car and look under the engine for a puddle of water.
  6. If there's no puddle and you have repeated the process several times, you may have to see the dealer.
Old Jan 16, 2020 | 04:50 PM
Mark SF's Avatar
I thought it was a straightforward matter for any shop to unblock the drain with an air hose from below / outside. It is common practice.
Old Jan 16, 2020 | 05:07 PM
Fraser Mitchell's Avatar
Is the air con working ? The refrigerant gradually leaks out over time and if less than spec, means its ability to de-humidify the air in the car is reduced. Maybe an air con service is needed. That's my tuppence worth anyway !
Old Jan 17, 2020 | 02:31 PM
Redmen's Avatar
Hi all, - 1st of all: thanks for the advises...
Step-by-step:
unfortunately there is no dealership in my area, at least 3 hours drive, and I had not so good experience with them...
I had cleaned the drains in my previous cars, but there is no one available on this however it should (may be it is in the top of the heat-child in the top of the transmission - so it can not be accessible...)
- yes I also thought it is common problem and easy solution / process, but as this thread shows it is not...
AC checked, pressure is OK, works correctly.
Actually I was surprised about the service manual that shows nothing about this problem.
Old Jan 18, 2020 | 12:32 PM
Often the drain tubes from the air con can be found after the wheel arch liners are removed. I'm not saying this is definite, but it might be worth a look.
Old Jan 18, 2020 | 12:57 PM
clubairth1's Avatar
Not on the XJ? I have looked and even had my car on the lift while running. All I can see is water dripping out and around the under-body shielding.
I also have cleaned condensate drains using an air hose before but there does not seem to be a hose where you can get access to it.
At least I have not found one yet and so far I can't find anything in the shop manual although I bet it's in there somewhere.
Ric Gallaher
Jul 1, 2017 09:39 AM
rttug
Jun 18, 2017 08:23 PM
kyle04
Jan 22, 2014 01:14 PM
spuddyo
Feb 28, 2013 04:01 AM
stevedorrance
Mar 15, 2012 04:30 PM
