XJ ( X351 ) 2009 - 2019
Window switches 2011XJL
Old Feb 11, 2018 | 02:08 PM
Donm's Avatar
Default Window switches 2011XJL
hi all,
all 4 window switches will lower and close all windows in the car but the auto down (the intermittent first switch closure) will not work on any windows.
any ideas? I can’t think all 4 switches have failed in identical ways all at once. The only thing done recently was having the right side outside rear view mirror was replaced and it works perfectly.
best regards
don m
Old Feb 11, 2018 | 03:58 PM
rhomanski's Avatar
Since the drivers door has all four switches in it, perhaps the drivers door electronics module needs a reset or replacement?
Is it inop from all four doors or only from the drivers switches? If you haven't try it from the individual doors.
Old Feb 11, 2018 | 05:12 PM
Donm's Avatar
Excellent line of investigation! Will do it and respond.
Thx!
Old Feb 11, 2018 | 07:31 PM
Thermo's Avatar
Veteran: Navy
Donm, have you recently lost power to the car (ie, ran the battery flat or changed the battery). If so, you simply need to reset the windows. If you need the procedure on how to do it, let me know. Fairly easy to do. Takes about 2-3 minutes to reset all 4 windows.
Old Feb 11, 2018 | 08:41 PM
Donm's Avatar
Thermo, thanks for the reply! As a matter of fact, just had new battery installed before this was noticed. Would you mind outlining the reset procedure?
best regards, Don m
Old Feb 11, 2018 | 09:27 PM
rhomanski's Avatar
It's in the owners manual, JimC64 has it in a sticky here. https://www.jaguarforums.com/forum/x...ownload-66380/
It's on page 158, but it says to close the window. Release the switch and then then lift to the close position again and hold for two seconds. Open the window fully,release the switch. Put it to open and hold for two seconds. Then try the one touch function.
Repeat for all four windows.
That's from my 2012 XJL manual.
Old Feb 12, 2018 | 06:47 AM
Thermo's Avatar
Veteran: Navy
Looks like rhomanski beat me to it. Granted, a slight difference that I see from the service manual is that it talks about moving the window and then continuing to hold the switch in the desired position vice letting go and then doing the switch a second time for the 2 seconds. When I reset mine, I simply held the button for the additional 2 seconds (may want to go a little on the long side time wise and you should also hear a faint click from a relay when it is set).
It may also be advisable to start the engine (says so in the service manual). Granted, as long as you can move the windows, all should be good.
Old Feb 13, 2018 | 07:35 AM
OWRltd's Avatar
These are some of the things that make me hesitate in my xjr 300 replacement. Training windows? Why can't it remember? Oh, yeah...Three fuel pumps? Don't see a future problem here!
Old Feb 17, 2018 | 08:14 PM
Donm's Avatar
Thanks everyone! That fixed It right up, yeah!
regard,
don m
Old Feb 17, 2018 | 11:52 PM
rhomanski's Avatar
Glad to be of assistance.
Enjoy the drive.
Old Feb 18, 2018 | 09:09 AM
clubairth1's Avatar
Community Influencer
Training windows has been done for decades and is used on hundreds of cars to prevent you from getting stuck or pinched in the power windows.
It's a simple thing and common.
Old Feb 23, 2018 | 09:05 PM
Gpfarrell's Avatar
Thanks for this thread... I read it a few days ago and fixed 2 windows while driving to work!
teroks
Oct 2, 2022 04:38 PM
MexicoBeachMichael
Mar 24, 2017 05:03 PM
super_jag
Oct 26, 2014 10:33 AM
86JAGVP
Oct 22, 2011 08:41 AM
djpxk8
Jun 2, 2011 09:36 PM
