XJ ( X351 ) 2009 - 2019
Wiper blade washer hose replacement
Old Feb 11, 2024 | 01:08 PM
GTxj's Avatar
Smile Wiper blade washer hose replacement
Hi folks,
I have an issue with the driver-side windscreen washer on the wiper blade on my 2014 X351 — while the passenger side washer works fine, I can see that the base of the hose that joins the blade to the cowl must be cracked/broken, as I can see the water spraying/leaking behind the arm's rotor when the pump runs.
It's 3 or 4 cm beneath the point where the pipe connects to the cowl with a square/cube-ended connector (weird!). So I need to replace the tube, and I expect that connector too. Photo attached (taken with a flash, bit of a mess, but at least you can see the square/cube connector) 👍
Might anyone be able to suggest where I could source these parts? Anyone else had to change them? Any and all advice really welcome
Thank you!!
GT
Last edited by GTxj; Feb 11, 2024 at 01:10 PM. Reason: Think I kinda forgot to add the attachment 🤦
Old Feb 11, 2024 | 06:05 PM
12jagmark's Avatar
Looks like a little growth on that wiper arm.
The part number for the grommet that the hose plugs into is C2C5840.
Your local dealership should be able to help you with that, or if you need the hose assembly they should be able to help you with that too.
Old Feb 12, 2024 | 02:35 AM
GTxj's Avatar
Thanks so much!! Can you believe I've never seen https://parts.jaguarlandroverclassic.com/ before? 🤦
And yes, it does need a good clean. The in-the-dark-flash-photo makes it look worse but that's British weather for you 🤣
Reading the wiper arm detail it seems that I'd need to replace the whole arm to replace the broken hose. To be honest I assumed I'd need to replace the grommet *if* I replaced the hose, but I think I'm going to remove the arm (carefully &#129315 and see if I can repair the hose 👍
Couldn't have got here without this info, thanks again 👍
Old Feb 12, 2024 | 09:13 AM
GTxj's Avatar
So, I think I've been quite lucky here There's a split (actually more of a slice) a couple centimetres from the grommet that I can easily reach and should be able to repair.
Looking at the routing of the hose I wonder if it's been wrapped underneath the rotor and trapped/sliced as the years have gone by.
I moved it over the wiper arm by rotating it clockwise around the grommet and it looks a lot more 'comfortable'. Could be completely wrong of course
Thanks for your help folks!
Old Feb 12, 2024 | 09:45 AM
clubairth1's Avatar
Community Influencer
Yes the wiper rubbed a hole in the hose. So it must have been routed wrong?
Old Feb 12, 2024 | 10:30 AM
GTxj's Avatar
Yep, I *think* so, but I've never had to touch the wiper arms, so either it's always been that way or a service has changed it.
If you look at the horribly grubby picture from yesterday you can see that same hose going beneath the rotor, which I think means it could have got trapped and damaged.
The assembly isn't the same on the passenger side (mine's a right-hand drive) so I've nothing to compare it with, but if I find a picture anywhere I'll drop a copy in here. Now it's time for some rubber repair.
Old Feb 13, 2024 | 04:02 AM
GTxj's Avatar
...or maybe I'd be better off with one of these... any thoughts folks? Thanks once again!
Old Feb 13, 2024 | 06:58 AM
12jagmark's Avatar
Here is a pic of the routing for the driver's side wiper arm on our XJ.
Hose is routed under the arm, into the channel that accommodates it as it runs up the arm...
And the same for the passenger side wiper arm..
Auto parts stores generally have various sizes and types of hose available that could replace the hose, although the fittings aren't as easy to find outside of the dealership.
I assume auto parts stores in the UK are also stocked with various hose offerings that you could take the damaged hose in for a match.
Old Feb 13, 2024 | 08:14 AM
GTxj's Avatar
Thanks @12jagmark , so yours is left-hand drive. This is the orientation that I found the hose in, perhaps it got trapped if the hose was tightened/pulled shorter after a blade change or similar. There's not a lot of play once the arm rotates about 90° or so.
vincent661983
Feb 21, 2022 04:07 PM
Mr Bentwrench
Jul 17, 2020 03:15 AM
rufeo690
Dec 23, 2018 04:22 PM
yeldogt
Apr 5, 2017 12:47 PM
marc4sgr
Sep 14, 2010 06:35 PM
