XJ ( X351 ) 2009 - 2019
XJR575 with weird starting problem
Old May 8, 2026 | 12:45 PM
  #61
k-xjr575's Avatar
Originally Posted by RoverJoe
You are correct, the LPFP is energized when the door is opened so there's no delay in starting.
on this point , let’s say if this signal interruption lands up being an issue ( after I put in all new OE parts), then is this an easy fix ? Or will this be a trip to the dealer kind of a thing
Old May 8, 2026 | 01:01 PM
  #62
k-xjr575's Avatar
Originally Posted by Vasara
The long pipe on tank might be the "balance" pipe between sides of the tank. The middle shaft tunnel separates the bottom part of the tank.
The balancing is made by "JepPump" effect using return fuel flow. If the balancing hose is lose, your pump side will run dry and your dash still show fuel. (two floaters combine the level)
Not sure what level the free flow of fuel stops because of tunnel, but i think its more than half tank.
This is well descripted on X351 Service and Repair manual
would you have a schematic or an excerpt from the manual that I can look at that’ll help me understand this better. The black tube that I had questions on comes out from under the white filter housing that’s immediately below the lock ring on the outside. It’s pretty short in length so I am not sure if it’s the balance pipe .. one end is hooked up to the nozzle u see the filter housing and the other was free floating in the tank (now connected onto the nozzle of the pressure relief valve as noted in @clubairth1 pictures .
if it’s relevant , currently the car has less than a quarter tank of fuel and seems to start up on first crank following my 2 step process of start button press without cranking followed by start button press with foot on brake to crank . FWIW, the low fuel pressure warnings initially started with the tank more than 3/4 full and persisted even after it was full .
Old May 8, 2026 | 05:27 PM
  #63
Vasara's Avatar
Hi,
Check Sticky section of this forum. You will find x351 Service and Repair manual. Its extreme good and usefull for any owner. (and big)
(i am in vacation on Spain and with bit limited gear)
Old Yesterday | 12:35 AM
  #64
JHendo's Avatar
Originally Posted by k-xjr575
In addition to my previous reply above, the tank looked very clean with hardly any debris in there. When you mention getting eyes on the filter, does the black part come out of the white housing that it sits in? Or is it one preassembled unit ? If I do land up needing to clean the tank, I am guessing then it will be a trip to the dealer? Or is there a way or a "tank clean" procedure that allows it to be performed with the tank still in place?
I was referring to the pickup screen. Any larger debris in the tank would be caught there, and any fines would be caught in the actual filter. Either can have this issue, only difference is the size of the particles potentially causing the issue.
Jeffrey Adams
Feb 26, 2024 07:05 AM
topanga
Nov 21, 2022 11:50 AM
Evan H
Apr 29, 2021 10:17 AM
thriftyshirt
Oct 14, 2017 06:51 AM
kgrosse
Aug 8, 2011 05:22 AM
