XJR575 with weird starting problem
on this point , let’s say if this signal interruption lands up being an issue ( after I put in all new OE parts), then is this an easy fix ? Or will this be a trip to the dealer kind of a thing
The long pipe on tank might be the "balance" pipe between sides of the tank. The middle shaft tunnel separates the bottom part of the tank.
The balancing is made by "JepPump" effect using return fuel flow. If the balancing hose is lose, your pump side will run dry and your dash still show fuel. (two floaters combine the level)
Not sure what level the free flow of fuel stops because of tunnel, but i think its more than half tank.
This is well descripted on X351 Service and Repair manual
if it’s relevant , currently the car has less than a quarter tank of fuel and seems to start up on first crank following my 2 step process of start button press without cranking followed by start button press with foot on brake to crank . FWIW, the low fuel pressure warnings initially started with the tank more than 3/4 full and persisted even after it was full .
Hi,
Check Sticky section of this forum. You will find x351 Service and Repair manual. Its extreme good and usefull for any owner. (and big)
(i am in vacation on Spain and with bit limited gear)
In addition to my previous reply above, the tank looked very clean with hardly any debris in there. When you mention getting eyes on the filter, does the black part come out of the white housing that it sits in? Or is it one preassembled unit ? If I do land up needing to clean the tank, I am guessing then it will be a trip to the dealer? Or is there a way or a "tank clean" procedure that allows it to be performed with the tank still in place?
Jeffrey Adams
Feb 26, 2024 07:05 AM
thriftyshirt
Oct 14, 2017 06:51 AM
