XJ XJ12 ( X305 ) 1995 - 1997
X305 diff ratio
Old Sep 29, 2013 | 09:11 PM
deelli's Avatar
Default X305 diff ratio
Could someone tell me what the gear ratio is for a diff in a 95-97 XJ6??
Old Sep 29, 2013 | 09:16 PM
Doug's Avatar
The 4.0 X300/XJ6 with auto trans (and the X305 with the 6.0 V12) the diff is 3.58 ratio
Old Oct 1, 2013 | 05:42 AM
SleekJag12's Avatar
Sadly, those USA models were not offered with a limited slip diff. Sure would like it, esp in the XJ12. Only the XJR and XJS got it, AFAIK.
Old Oct 1, 2013 | 08:45 PM
motorcarman's Avatar
I have seen VDPs with the LSD. I don't know if any or all V12 cars were fitted.
Sometimes the cars get a replacement and a different diff gets installed.
I have a limited slip in my 1992 XJ40 but I installed it myself.
Look on the tag on the diff and it should be a red/yellow for 3.58.
If it has a BLACK 'X' through it it IS the LSD version.
bob gauff
Old Sep 17, 2023 | 11:36 PM
944play's Avatar
Old thread, I know, but my pedantry must be assuaged. The "Vehicle Care" manual states it's a 3.54, not 3.58 rear end.
Old Sep 18, 2023 | 02:45 AM
SleekJag12's Avatar
I've seen that spec too John, don't let it get to you! It is a small difference. I wonder which one is correct? Someone with a diff in their hands would be able to find out. At any rate, the XJ12 should have been built with the 3.27 Powr-Lok. I'm pretty sure the older V12 drivetrains had LSDs or at least as an option.
I hate those stupid trade names that are made up of misspelled real words that is somehow supposed to describe their function.
Old Sep 18, 2023 | 04:36 AM
944play's Avatar
I'm certainly not fussed about a ~1% difference -- that gets dwarfed by just tire wear. I just want my (future) Cars&Coffee 'brag sheet' to be numerically factual.
That said, I have no idea whether the Solars I have actually came off a 2003. Mental note, look for datestamps next time they're off.
Old Sep 18, 2023 | 07:07 AM
Doug's Avatar
The Jaguar parts catalog for the X300 shows four available ratios, 4:09, 3:77, 3:58, and 3:27
Go to item #22 here:
https://parts.jaguarlandroverclassic.com/parts/index/part/id/922.1585.5727.24373/brand/jaguar/
The XJR/6 used the 3:27
The V12 used the 3:58 as did the 4.0 normally aspirated/automatic
The 4:09 and 3:77 were for 3.2 and 4.0 normally aspirated with manual transmissions, respectively
I have seen the "3:54" in some publications as well.
I'm reminded of a similar situation with the specs on the older Series III XJ6 diffs. The sales literature shows 3:07 as does some service literature. The parts catalog shows 3:058, 3:06, and 3:07 !
Old Sep 18, 2023 | 07:26 AM
Doug's Avatar
Curiosity getting the better of me I looked up the XJ40 specs in the parts catalog
The ratios listed match the X300 ones I mentioned above....after a certain VIN (which I didn't make note of).
Earlier XJ40 shows 3.54 and later shows 3.58
<shrug>
Old Sep 18, 2023 | 02:20 PM
944play's Avatar
I googled the part number for the crown and pinion and found this image:
I counted 43 teeth on the ring gear. A 12 gear pinion would be 3.583̅. 3.54 has to be wrong!
Old Sep 19, 2023 | 01:46 AM
SleekJag12's Avatar
That must be the solution! A 43 tooth ring gear. 43/12. A 42 tooth ring gear gives exactly 3.50 which doesn't make sense to call 3.54. Impressive detective work! There should be multiple examples of this in YT diff rebuild videos to verify.
David Bradley
Dec 10, 2021 06:03 PM
slowy
General Tech Help
Dec 4, 2017 08:08 AM
Sterlingcousins
General Tech Help
Jan 14, 2014 07:56 AM
JaguarXKR
Feb 25, 2013 07:44 PM
colindavies
Jan 21, 2011 06:51 PM
