2006 Super V8- Rust
Old Nov 3, 2018 | 06:47 PM
JaguarXKR's Avatar
Default 2006 Super V8- Rust
Evening all,
I went to look at this 2006 Super V8 Portfolio this morning down in Ohio. I found a few rust/corrosion spots on the vehicle which made me reconsider wanting to make an offer on the vehicle. I was under the impression that aluminum vehicles don't rust. Is this a common issue with the x350?
I also noticed the front bumper on the passenger side was resprayed. The rear suspension also looks like it needs an overhaul with the bushings, etc.
https://www.autotrader.com/cars-for-...ckType=listing
Old Nov 4, 2018 | 01:48 PM
alecescolme's Avatar
Very common in those areas, nothing to really worry about
Old Nov 4, 2018 | 03:39 PM
Fraser Mitchell's Avatar
What you have seen is the classic aluminium corrosion syndrome called "crevice or filiform" It occurs in the absence of oxygen, unlike steel rusting that relies on it. It is a bit of a nuisance as it looks unsightly, but is generally not something that is going to affect the integrity of the car. I had the same corrosion and in the same place as yours on my last car, and it was present on my current X358, but is now dealt with. You have to scrape out all the white powder, which is aluminium hydroxide, and get down to bare aluminium. Paint on zinc-rich primer, then ordinary primer, then make the surface level with acrylic stopper. Flat off and finish as normal with base and clear coats.
Old Nov 5, 2018 | 01:15 PM
roviw's Avatar
I have it on my car as well, as mentioned above it is common. Mine had only slightly worsened in the 4 years I have had the car.
Old Nov 7, 2018 | 08:39 AM
AftrBrnr's Avatar
Same here on my 2004 XJ8. I have two small spots that aren't noticeable unless you're looking for them.
Old Nov 7, 2018 | 09:03 AM
ooootis's Avatar
you might also consider treating the area with alodine prior to the zinc (which IMO isn't required if you alodine). Alodine is more expensive: https://www.ellsworth.com/products/b...ing-40-ml-pen/ For a quick example ! didn't shop it.
Old Nov 8, 2018 | 03:13 PM
06-XJR's Avatar
Technically it's not rust because yes aluminum doesn't rust. But it does corrode. Stuff like that on aluminum is more of a cosmetic concern whereas rust on a steel car would become a structural issue and spreads much faster.
Old Nov 11, 2018 | 01:21 PM
JaguarXKR's Avatar
Would anyone know an estimated cost to restore these two areas?
Andreas Pavlos
Dec 6, 2017 09:35 AM
newfire
Jan 21, 2012 09:38 PM
SergeXJR
Jun 20, 2011 06:51 AM
stealthauto
May 28, 2010 02:02 AM
Sixx Dogg
May 16, 2010 05:19 PM
