Ballast replacement.....done
Old Jun 14, 2015 | 12:56 PM
VinnyT's Avatar
Default Headlight ballast replacement.....done
1.5 hour job. Not bad at all. I must have saved at least $800 or so doing it myself.
Cheers!
Old Jun 14, 2015 | 10:22 PM
Don B's Avatar
Hi VinnyT,
Just for the sake of clarity, was it the HVAC blower motor ballast circuit, an HID headlamp ballast, or some other ballast that you replaced?
Thanks!
Don
Old Jun 15, 2015 | 12:34 AM
VinnyT's Avatar
Sorry, HID ballast.
Old Jun 15, 2015 | 08:26 PM
Sorry, HID ballast.
Vinny, that's great , thanks so much for sharing.
Now - where's the write up c/w pics and or video how to??
Old Jun 16, 2015 | 07:22 AM
VinnyT's Avatar
I can do a pic/write up instruction for this. Anything to help us owners save a few bucks...
Old Jun 22, 2015 | 11:49 PM
trosty's Avatar
Any joy with that write up/pics as I am shortly going to be needing to change mine I think. Did you replace the ballast because of flickering headlights?
Old Jun 23, 2015 | 06:59 AM
VinnyT's Avatar
Yes, the flickering started before it went out. When I pulled the old ballast, it has a coating on corrosion all over it. Seems to get a lot of moisture in there.
I will do a write up this weekend with pics. Really not a bad job at all.
Old Jul 1, 2015 | 02:32 PM
Seth's Avatar
Also looking forward to your picture write up :-;
Old Jul 3, 2015 | 08:02 AM
ryejag's Avatar
Replacement ballast part number? where did you obtain the replacement part? I have a 2004 XJR and believe I need to replace a ballast due to flickering. I have seen some locations that rebuild these units as well
RyeJag
RonnieJoe
Sep 22, 2015 04:10 PM
RonnieJoe
Sep 21, 2015 08:25 PM
jjd
Sep 20, 2015 09:46 AM
avern1
Sep 8, 2015 06:25 PM
