Brake Fluid Flush
Dear Forum,
Given the somewhat complicated (but very effective) braking system on our Jaguars, when flushing my brake fluid, please could someone tell me whether I can use one of these systems that enable you to pump new brake fluid from the bleed nipple on the calipers UP to the brake reservoir?
(Read EsRay's Post #6 BEFORE replying - GGG)
I ask because (obviously) the 'uphill trajectory' of these systems is simple and very good at not allowing air in?
But would there be any problem's with our ABS, Park Brake systems etc, please?
I have a power (hand pump air) brake flush system. It screws on the top of the reservoir.
Works great, but is normal, fluid is pushed through the master cylinder to the ABS pump to the calipers. Works way better than pumping the pedal.
Sourced mine from ECS Tuning. Schwaben brand. But may be the same as Motive.
Been using it for 5 years. No issues yet. Used it on XJR, A8, and 335. A8 and 335 twice after ABS controller issues. So maybe five times.
My apologies Meirion1; I was borrowing the bleed kit in question from a friend who told me that it used a pump at the caliper? I have misunderstood his explanation; It does use a pump at the caliper (not at the reservoir), but not to create air pressure to push, rather it creates a vacuum to draw the fluid out when the nipple is loosened. Now when I think about this, it should have been obvious to me!
So, you are right not to have heard of it or to fancy it!
Mity Vac sounds like the tool you described, i have used them for years.
To flush the brake, & clutch fluid in motorcycles, & cars .
But when i tried to use it on the Jaguar it failed to work like always.
For some reason you had to pimp the pedal.
Draw the old brake fluid from the master, then refill it with fresh fluid to start, however you flush.
The old hose on the bleeder, then into a bottle with the old brake fluid, from the master was how i changed mine.
The bleeder is left open, the other end in the fluid keeps you from drawing air back into the system.
Then just pump it through till clean fluid is pumped out
I also have the syringe type tool, that pushes the fluid from the bleeder up to the master cylinder.
I like the Mity Vac better, but the old hose in the fluid trick, has ALWAYS worked for me.
Its the cheapest way as well, i hope this helps you and others.
I used a pressure fill process at the reservoir.
A container with the correct brake fluid is attached to the reservoir and pressurized so no air between the reservoir and the fluid in the pressurized container.
Then release each brake caliper nipple in the correct sequence and watch for clean fluid to be expelled.
Worked like a charm.
The Motive Products power bleeder mentioned previously is approx. $70. It's basically a garden sprayer with a pressure gauge on it. I bought this for a Corvette brake project, just need to get the correct adapter for the Jag master cylinder reservoir. They sell adapters for most vehicles if you go to their web site.
Just wanted to mention, the Jag brake system is pretty bog standard ABS, and aside from a minor issue bleeding the rear calipers when rebuilt, shouldn't cause any issues to flush or bleed.
All in all less than $60.
It may be like a lot of EU Auto products, Volkswagen, BMW, LR all buy brake fluid reservoirs from the same supplier.
