Codes U1262, B2496 & B2533
Old May 29, 2019 | 11:21 PM
EsRay's Avatar
Default Codes U1262, B2496 & B2533
Dear Forum,
Please could someone help me with the attached codes:
The Driver's Door Module (U1262) may well be that I need to replace my non-functioning passenger rear door Actuator? I think?
However, the Security Horn (B2496) has me puzzled as it appears to be working normally?
And the same for the Right Hand Rear Stop Lamp - Again, seems to be working okay?
Thank you.
Old May 30, 2019 | 02:03 AM
toyman1001's Avatar
Have you cleared the codes only to see them again?
Old May 30, 2019 | 02:30 AM
EsRay's Avatar
Yes
Old May 30, 2019 | 04:40 AM
meirion1's Avatar
I my experience a failed door lock has allways been the actuator itself and not the DDM.
I seem to remember that there has been a problem with a DDM connection in the past
and reported on this forum.
I think also that the DDM is on the wrong side of the moisture barrier in the door.
Therefore I suggest that you have a look at that and unplug/replug the connectors and clean with electrical cleaner.
It might be a good idea to replace the relevant fuse-in very rare cases there can be a problem with the fuse itself.
Fuses listed in Owners' Manual
Old May 30, 2019 | 04:54 AM
EsRay's Avatar
Thank you Meirion1,
My Drivers Door works okay (most of the time); it's my rear passenger door that has the dud Actuator....(very shortly to be replaced)...And maybe the DDM is reacting to that and throwing this fault? What do you think?
As for the other two codes, they relate to faults that do not appear to exist, but keep returning after being cleared?
Perhaps I should just ignore them (apart from replacing the passenger rear door actuator) and be grateful that these are the only Fault Codes I currently have.....But you know how you get with these beauty's.....like a dog with a bone!!
However, I will whip the driver's door card off and spray connectors, as you suggest.
Old May 30, 2019 | 11:43 PM
EsRay's Avatar
I sometimes get a small shock when pressing my boot opening button; I have been putting it down to a static charge? Perhaps its a leak to ground from my Stop Light and this is what is causing the fault code, despite the fact that my stop light is working correctly?
Does its circuit only become live when I press my brake pedal, or (like the reversing lights) does Jaguar have that strange arrangement they seem to favour of a constant live and then making the circuit using the ground wire?
Please excuse my lack of auto electrical knowledge, but how do I test this, please?
Old May 31, 2019 | 01:15 AM
Cambo's Avatar
Every X350 I ever scanned had these faults stored, and many other random ones that made no sense.
As everything is working fine, don't worry about them, they all have these fault codes for whatever reason.
You just need to change the door lock assembly, they all fail eventually, I've had to replace every door lock in my XJR.
Old May 31, 2019 | 01:30 AM
EsRay's Avatar
Thanks Cambo,
I'll do exactly that!
Old May 31, 2019 | 03:27 AM
As everything is working fine, don't worry about them, they all have these fault codes for whatever reason. .....
A scantool is a wonderful aid to troubleshooting but too many members will use them to go looking for trouble!
When a Jaguar is running OK, enjoy it. Many "faults" are recorded simply because a sensor has momentarily gone out-of-range and should not be taken as an indication of impending catastrophe or that the vehicle is about to grind to a halt.
Chill out ....... providing of course your AC isn't showing any faults.
Old May 31, 2019 | 07:40 AM
EsRay's Avatar
Okay, that's a very sensible attitude to take providing any potential short circuit being coded is not draining your battery.
Please help me to learn something from this:
Please, what does N, DD13, -3,-4 and B+ voltage mean?
Old May 31, 2019 | 11:59 AM
JagV8's Avatar
It'll be a connector & its pins. B+ means battery +
See the workshop manual / electrical guide.
For the N, see the codes PDF. I think it'll be whether the code puts the MIL on but be sure to check.
Old May 31, 2019 | 12:01 PM
EsRay's Avatar
Thanks JagV8.
Now I know....!
philwarner
Nov 30, 2020 10:55 AM
jczaban
Mar 16, 2019 03:03 PM
martinrupp
Apr 13, 2018 02:39 PM
bassman64
Apr 20, 2014 04:25 PM
XTypeJagMan
Feb 28, 2014 08:38 AM
