Config B error
Old Aug 3, 2010 | 11:17 AM
mattrains's Avatar
Question Config B error
Hi Everyone,
I recently installed bluetooth in my car and now i'm getting a config B error on my dash. My car didn't come equipped with a phone so I bought a PSE module (the newer series), the bluetooth module itself, the microphone, and the connector that loops off the where the voice module is in the back. The connector came in after everything else so before it came in I brought it to the dealer to have it flashed and the phone added to the cars programming. They weren't able to get the computer to talk to the phone module and the CONFIG B error remained. At that point I didn't have to Voice loop installed yet so is it possible that would not allow the computer to program the phone module? The whole system works perfectly without any glitches and the car is working great, but I keep getting the CONFIG B message on my mileage display along with the red and yellow flashing lights. Does anyone or any of the techs on here know what might be going on, or if I should take it in and try again now that I have to connector loop installed?
Thank you in advance for your help!
Mat
Old Aug 5, 2010 | 01:40 PM
mattrains's Avatar
I'd really appreciate it if someone would help me out with this.
Thanks,
Mat
Old Aug 5, 2010 | 03:28 PM
Drew's Avatar
I hope this helps.
File Type: pdf
Old Aug 5, 2010 | 08:00 PM
veffremov's Avatar
I know it's a lame suggestion, but have you tied disconnecting the battery to reset the computers?
Old Aug 5, 2010 | 09:14 PM
u102768's Avatar
Well it worked for this guy:
http://www.jaguarforum.co.uk/viewtopic.php?f=22&t=29834
Old Aug 6, 2010 | 10:44 AM
mattrains's Avatar
Thanks for the replies,
Drew,
I followed those directions when I installed the system.
veffremov and u102768,
I tried unplugging the battery overnight and I also tried touching the positive to the negative the discharge all of the capacitors but none of that made a difference.
Mat
Old Aug 6, 2010 | 12:10 PM
mullisrd's Avatar
I had this happen to me when I had the IDS programming done when I added NAV. If I remember correctly, you will need to have whomever is doing the IDS programming to clear the module and then to a total reload of the software according to your vehicle specs. You will have to do it with IDS, there's no reset that you can do yourself.
Old Aug 6, 2010 | 09:25 PM
mattrains's Avatar
mullisrd,
Thanks for the advice I will try to get it reflashed again at the dealer on monday and tell them that they need to completely clear the module first.
Mat
ricwel
Jun 23, 2023 05:14 PM
magmedia
Aug 15, 2019 08:54 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Poet
Oct 2, 2015 09:00 AM
Collector1
Sep 28, 2015 03:52 AM
