Determine suspension type
Old Apr 15, 2014 | 04:28 PM
Hooshee's Avatar
Default Determine suspension type
Dear All,
I have just bought a 2006 XJR recently, and when I was on inspection last week it turned out that one of my shocks is nearly out, so I have to change it in the near future.
I have a quote from a local dealer or air springs (I suppose they are going to be Bilstein ones), but they asked whther I have sport or comfort suspension.
I would think it's sport, as it is an XJR, but I'm not sure, how can I easily find it out? I cant see the paint dot on the top unless I unmount it... Maybe a VIN decoder or something tells it for me?
Are the sport and the comfort springs interchangeble?
Barna
Old Apr 15, 2014 | 04:58 PM
meirion1's Avatar
Yes the sport and comfort shocks are interchangable.
What do you mean when you say a shock is "nearly out?"
Old Apr 15, 2014 | 08:14 PM
Don B's Avatar
Originally Posted by Hooshee
Dear All,
Barna
Hi Barna,
Yes, the sport and comfort air shocks are physically interchangeable, but naturally they have different damper rates and ride quality. You may be able to see the paint dot using a small mechanic's inspection mirror. I would be surprised if your XJR was equipped with comfort shocks - they are almost certainly sport shocks.
Meirion1 asks an important question as to what is actually wrong with the shock. If air is leaking from that corner of the car, it is possible that you just need to replace the O-rings on the air hose and pressure valve fittings. Check the recent thread on this forum with "Viton O-rings" in the title for some information about this.
If the air spring bladder itself is failing, unfortunately we have not yet found a source of replacement bladders, so the shock will need to be replaced. Arnott Industries re-manufactures OE Bilstein shocks and also manufactures their own "up-rated" replacement shock, so you might check out their website to see if their parts might save you some money. I have no affiliation with the company, but several members of this forum have reported good success with Arnott products:
https://www.arnottindustries.com/products/
Cheers,
Don
Old Apr 16, 2014 | 01:36 AM
Hooshee's Avatar
Thanks for the answers guys, I really appreciate it. The nearly out means, that here in Hungary, during the annual inspections, there is a system which shakes the wheels, and measures the efficiency of the shock (sorry, I don't know the correct phrase for that machine). One of them (front right) is underperforming all the others. Otherwise, the levelling is working, there is nothing wrong with the air part...
Old Apr 16, 2014 | 03:49 AM
Cambo's Avatar
Welcome to the forum Hooshee, you should stop by our new members area and introduce yourself there too ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
As it's an XJR, it 99.9% will have Sport suspension, only way it wouldn't is if a previous owner changed all four shocks to comfort, for some reason, which is pretty unlikely...
Old Apr 16, 2014 | 01:28 PM
Fraser Mitchell's Avatar
Right at the top side of the air spring unit will be a 2 cm diameter dot, Red=Sport, Green=Comfort. You'll have to remove the wheel arch liner to see it. However, an XJR came with Sport springs from the factory.
So if you buy a Sport air spring unit, (Red Spot), on eBay, it will be correct for your car.
Old Apr 16, 2014 | 05:04 PM
Cambo's Avatar
Thanks Fraser, that's great info!
Old Apr 16, 2014 | 05:07 PM
meirion1's Avatar
I suggest that you need to understand exactly what is wrong with the shock, it
may save you money if for example just the bottom bush is worn since this can
be replaced.
Old Apr 17, 2014 | 03:51 AM
Hooshee's Avatar
The bush seems to be ok, but of course I will look after before buying anything
Thanks guys!
Old Apr 17, 2014 | 05:44 AM
Rear spring units have the lower bush at the bottom of the unit, fronts have it in the wishbone, (the straight one).
JarodL
Mar 7, 2024 01:39 AM
way2far
Aug 31, 2022 09:26 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
