Does an Engine ECU need to be coded to car
Old Sep 8, 2015 | 01:22 PM
joesoap's Avatar
Default Does an Engine ECU need to be coded to car
Hi, I seem to have a duff Engine ECU on my XJ6 3,0L 2003.
Can i put in replacement from another car and just start it?
Old Sep 8, 2015 | 05:37 PM
JagV8's Avatar
Almost certainly not. See if anyone knows more but don't even try it before being sure. Cars like mine go into anti-theft and it's a dealer tool to get it out.
But... they hardly ever fail so probably you've not quite figured out the fault.... er and what is it???
Old Sep 8, 2015 | 06:16 PM
Don B's Avatar
JagV8,
See joesoap's other thread in which he describes the malfunction. Hopefully you'll have some good ideas that haven't been mentioned:
https://www.jaguarforums.com/forum/x...-spark-149361/
Cheers,
Don
Old Sep 8, 2015 | 06:57 PM
doc's Avatar
doc
If it's like all my other cars it will need to be coded to your car
I just bought a second hand Ecu for my wife's jeep a very expensive exercise
Old Sep 9, 2015 | 01:19 AM
JagV8's Avatar
Don - thanks.
I'm a bit worried to have 2 threads about different aspects of the same problem......
Old Sep 9, 2015 | 04:17 PM
34by151's Avatar
If you replace the ECU you need to code it to the car using SDD "Replace Module"
34by151
Old Sep 9, 2015 | 05:54 PM
Don B's Avatar
If evidence emerges that the topic of this thread is actually related to the symptoms reported in the other thread, I'll merge the threads.
Old Sep 10, 2015 | 11:29 AM
joesoap's Avatar
Default Sorry for Confusion
Sorry for starting another thread but was just looking for a yes no answer as I could get a used ECM for 50-100 pounds and eliminate that from possibles or cure the issue?
This one should die soon as answers confirm it needs SDD which I have, but not exactly confident yet?
Old Sep 10, 2015 | 01:09 PM
Cambo's Avatar
You can't just simply plug the ECU from another car into yours, it needs to be coded to your vehicle. There are various security measures in place that prevent swapping ECUs without programming with IDS/SDD.
fast40driver
Apr 19, 2024 07:24 AM
Isoruku
Jun 19, 2020 12:54 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
daro31
Aug 27, 2015 09:26 AM
NinoGrimace
Aug 26, 2015 05:15 AM
