Electrical problem
Old Oct 16, 2021 | 06:56 AM
Bluenose007's Avatar
Default Electrical problem
When I turn on wiper blades my engine cuts out. Can anyone help??
Old Oct 16, 2021 | 11:13 AM
abonano's Avatar
Chexk your chassis grounds behind the headlights..
Old Oct 16, 2021 | 03:48 PM
Jacuar's Avatar
Could also be a voltage issue. Check to make sure your battery and charging system are in top condition.
Old Oct 16, 2021 | 04:25 PM
ChrisMills's Avatar
"bad ground on the front of the car", post #43, #51
Engine quits when w/s wipes turned on - Jaguar Forums - Jaguar Enthusiasts Forum
meirion1's Avatar
Without doubt it is the grounds behind headlights.
What am I saying? I mean earths.
12 years on this forum is too long.lol
Old Oct 16, 2021 | 04:30 PM
ChrisMills's Avatar
Glad you haven't gone to ground yet.
Old Oct 16, 2021 | 07:51 PM
garethashenden's Avatar
I had this issue, it was the grounds behind the headlights. Take the nuts off and clean everything, but be careful putting them back on. Its very easy to snap the studs...
Old Oct 16, 2021 | 10:14 PM
veffremov's Avatar
To be fair it is neither earth nor ground - the car is quite isolated from the ground/earth running on thick rubber and all. Thechnically negative battery terminal / power supply connection.
Old Oct 16, 2021 | 10:37 PM
ChrisMills's Avatar
To be fairer, everyone knows what Ground or Earth means WRT to a car (for the avoidance of doubt it means the chassis), or if not they should call their nearest Authorised Repair Centre. (Center).
I would also agree with Jacuar, that the state of the battery or at least having it charged, is a really simple and first thing to try. There's plenty of threads to say a low battery can cause all sorts of errors (and not just on Jaguars). I have 7 battery chargers and 4 vehicles...Well? at least it's better than stamp collecting!
There is reported (also by me) that the indicator switch can cause headlight issues, such as going out on a dark and stormy night, due to worn wires. But that's not this issue.
This issue has 3 reported definite fixes that I can find. (all front ground studs). Water in the ECU due to blocked drains suspected never proven.
Not to put too fine a point on it (Users Handbook: Battery)
Caution: Disconnect the negative lead (earth terminal) first. (common parlance rules!)
To be more succinct, oh never mind.
seaace
Sep 30, 2021 09:46 AM
brinny
May 11, 2020 01:56 AM
nyboomguy
May 8, 2020 12:01 AM
Lanny Edgeman
Jan 8, 2012 12:58 PM
89JAGXJ6
XJ40 ( XJ81 )
Oct 18, 2010 03:51 AM
