So, from what I understand now, it's normal wear and tear, normal end of life with no possible repair/restoration of a unit that has served for 15 years or alike?
Which makes the used unit I purchased likely to be as good/bad a my original?
I'm sure restoration might be an option if the right person/shop is located. My old unit worked intermittently, then even less.
For me the tell tale sign was the burnt smell when the unit case was opened.
Ok so I installed this "new" Nav unit I purchased on Ebay for $45. I noticed that it is about 14 months "younger" than my original unit with a different part number.
So was a little worried it might not operate.
I also wondered if it had a disc in it as the unit was simply cut from all linked wires etc.
It did have a disc in it and it was jammed.
So removed disc and re-installed the unit and cleaned it with a head cleaner.
Put in the disc that was in it and it worked.
From the part number on the disc it is a USA/Canada 2005 disc.
Will button everything up and put my 2012 disc in after trying a couple of copies I made a while back.
So none of the copies worked.
I put my 2012 disc in and initially it did not work however after a minute it started updating the software which took maybe 10 minutes and now it works.
Tried a couple of the copies just in case and no go.
is the 2012 disk a different pn? Which disk did u use? Ive seen them for denso nav systems. Is that what we have?
Both NAV DVD players that I have now are labeled as Denso but different part numbers.
The DVD I have is for 2011-2012, and that is on the DVD label, which is the last year they were made. It has both a Jaguar part number as well as a Denso part number.
The DVD that was in the unit I purchased has both a Denso and Jaguar part number and the 2005 date I got from looking up that part number as the DVD itself has no date label on it.
