front lower control arm bushings
Old Dec 9, 2010 | 08:37 PM
eastsidejp's Avatar
Default front lower control arm bushings
are leaking. Can I just buy the bushings and does anyone have a resource for them? Thanks!
Old Dec 9, 2010 | 08:54 PM
sunbugone's Avatar
I think you are stuck buying the whole control arm. The rearward arm has a replaceable bushing. I have the same problem and I am looking into bushings for other cars as possible replacements
Old Dec 9, 2010 | 11:47 PM
amcdonal86's Avatar
I remember when I had to replace the lower control arms on my Lexus. I whined about how each of them cost $250 or so. Now I have a Jag with air shocks that can go bad with little notice and cost $1500 each. It really puts things in perspective for me!
Old Dec 10, 2010 | 04:57 AM
eastsidejp's Avatar
Thanks guys. Too bad there is not an aftermarket source with a non oil filled bushing... JP
Old Dec 10, 2010 | 08:01 AM
sunbugone's Avatar
all these high end cars have oil filled bushings and motor mounts including the electronically controlled type. They are all super expensive and in most cases the manufactures redesign them after thousands of failures. They redesigned the ones that go on the Phantom and they are no longer oil filled. I replace them all the time. I need to measure some of the bushings in my parts dept to see if they will fit or come close to fitting. On the subject of front struts, Arnot Industries has rebuilt units for about $400ea. They also have a lifetime warranty. My car needs them but my VW is in the bodyshop draining my savings account, so they will have to wait
Old Dec 10, 2010 | 12:47 PM
eastsidejp's Avatar
Thanks Sunbugone, please let me know if you find anything comparable
JP
Old Dec 10, 2010 | 04:31 PM
eastsidejp's Avatar
I found a source for the bushin only in the UK
http://www.britishparts.co.uk/.sc/ms...&go.x=9&go.y=7
JP
Old Dec 10, 2010 | 05:04 PM
eastsidejp's Avatar
This company in California has the bushing for 36.00
http://www.xks.com/
part # C2C4437
JP
Old Dec 10, 2010 | 05:45 PM
sunbugone's Avatar
That is the solid bushing for the rearward control arm. The front one is oil filled and not available as a separate unit. Maybe we are talking about two different arms? Gaudin has the same thing for $30, you can also look at it in the illustration
http://www.gaudinjaguarparts.com/par...&siteid=214626
Old Dec 10, 2010 | 07:30 PM
eastsidejp's Avatar
I'll have to double check with my technician. He printed out the diagram and identified the part # from alldata, so I will have to see if it is correct. Thanks for the heads up. JP
Old Dec 11, 2010 | 04:29 PM
Chuck08XJR's Avatar
Welcome to the Jag World. Believe me it's worth it.
Old Dec 22, 2010 | 05:23 AM
eastsidejp's Avatar
Sunbugone, do you have a part# for the arm that contains the oil filled bushing? You were right about that other bushing, not correct. I am still trying to see if there is an alternative or after market without much success. Thanks, JP
Old Dec 22, 2010 | 06:49 AM
user 2029223's Avatar
Banned
The lower control arm, complete with all bushings (sometimes called the wishbone arm), is part # C2C026835. It was avail from Welsh enterprises for $285.95 as of 1 yr ago.
The oil filled bushing is part # C2C026267 but hard to find seperately anywhere due to the difficulty installing it, apparently requireing a press and special fixtures. The Jag parts list calls it out but I don't think Jag sells it seperately.
You will need a front end allignment after replacing the lower control arm but if you pay carefull attention to the position of main wishbone arm alignment bolt, you can get it in the ball park. There was a description of this whole opperation about a year ago. Do a search in this forum or Suspension & Handeling or General Tech Help and you may find it.
Old Dec 22, 2010 | 01:10 PM
eastsidejp's Avatar
Thanks very Tarheal,
I called Welsh and they are 495 each- yikes!
Are the wishbones left and right side specific or the same?
Old Dec 22, 2010 | 01:16 PM
eastsidejp's Avatar
meant to say thanks very much
Old Dec 22, 2010 | 01:50 PM
Banned
Wow. That's quite a price bump! According to my parts list, the # is the same for R&L lower control arms. So it looks like they are identical. Your supplier can verify.
If you'er doing this job yourself, be aware, it is possible to install this part upside down. Don't ask me how I know this.
P.S. look in Gen Tech Forum for "lower wishbone arm replacement" from a yr ago. It's all there.
Old Dec 22, 2010 | 07:17 PM
eastsidejp's Avatar
Thanks Tarheal,
I looked up your post, very helpful. I am going to order the wishbones and have my indie replace them next week. I can't believe the price bump from last year. It sounds like these fail all too frequently. JP
SouthernGypsy
Sep 3, 2015 10:54 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
